Chainsaw Jim
Con Artist LLC
- 2:42 PM
- Feb 8, 2016
- Springfield Oregon
Time for a reed block!
PossiblyTime for a reed block!
I have a couple of those, and even held one up at one point lolThe four sided pyramid type from old Homelite saws might be a good simple design to check out. View attachment 101419
The Homelite 4 side, a WB or WJ, & you are but a Green weenie away from Making an ECHO relative to the Big woods again.
Come On!!
Didn't someone weld a block around the intake and machine it out? @srcarr52 @Chainsaw Jim
You think it's worth the time to reed block a ms361?I've welded on many intakes blocks, or welded around the stock one to make it bigger.
Any issue with the plating after?I've welded on many intakes blocks, or welded around the stock one to make it bigger.
You also use the mandrel in the bore, which I believe is a huge help. Just wanted to remind others about that extra step in setup.Only on AM cylinders.
Don't give away all my secrets!
Also welding little bits at a time helps.
Find me a big chunk of copper, Rod.
