Cylinder extension had to be turned down a bit in diameter to fit the echo case. The ex side bolt holes lined up perfect, intake side needed to be opened up a bit.
Both saws share a 13mm piston pin (cs8000/395xp)
Got the 395 jug to fit the echo case, try the 395 piston it is .220 squish.... Not good. Couldn't find a taller piston.
Thought the rod was shorter on the echo, not the case. Both rods are 70mm.
So I press apart the echo rod, of course it has odd bearing sizes. Only rod I could find was 10mm longer... luckily the 395 piston is about the tallest piston made lol. 066 BB piston skirt wasn't wide enough to cover the ports, so I try a 056 mag2. The dome just kissed the band. Hence the pop up.
Parts list so far
Echo case,covers,crank.
Husqvarna 395 cylinder, am 372 muffler
Stihl piston/pin bearing
Honda connecting rod
Poulan wj carb most likely
And a whole bunch of extra/scrapped pistons,cranks,rods
