Jonsered 2171 build disaster
astnmacgto
Earn a living with white powdery substances
10:27 PM
6. Pic of the base where it was shaved down to the fin on one corner. By measuring the base and comparing it to two other cylinders I have here it appears the took off somewhere in the neighborhood of .090 on average, I say this because you can tell just by looking that the base isn't square.20170918_065817.jpg
7. Pic of the pop up and wierd scuffing on intake side.20170918_065927.jpg 20170918_065943.jpg
So what do y'all think of this *s-word.....
@Mastermind
@Termitebuffet
@drf256
@Miller Mod Saws
@blsnelling
@tree monkey
11:27 PM
That corner is thinner normally. They used a cut off wheel or end mill burr like you said to work the uppers. The corner with the square corner is normally about .289" from my notes and had one at .312" with 7 jugs I have notes on.
astnmacgto
10:27 PM
Yeah I measured one of my good ones right at that 289 mark, this jug was right around 190
jacob j.
Only the weird
8:27 PM
Coastal Oregon
Those upper transfers are a train wreck. That cylinder is pretty much garbage unless a person wants to invest a lot of JB weld.
beaglebriar
The Peanut Gallery
11:27 PM
Warren Center, PA
Flywheel is still usable. I'm curious what the timing numbers are on that jug? How well did it run?
astnmacgto
10:27 PM
Guy said it ran great but I went in for a preliminary inspection and I found some questionable things, so I went ahead and tore it apart. I couldn't get a spacer made for my timing wheel so I tore it apart without getting numbers :facepalm:
David Young
Safety First !!!!!!
11:27 PM
vt
I think I have a flywheel for you if you want or need it.
beaglebriar
The Peanut Gallery
11:27 PM
Warren Center, PA
I'd slap it back together and run the piss out of it. What do you have to lose??
astnmacgto
10:27 PM
True very true, It would just bug the hell out of me knowing it is like that
astnmacgto
10:27 PM
I may have to take you up on that, I have a 2165 I'm building for 3 cuts at a time so I may put this flywheel on it and get another one for this one
