blsnelling
Friend of the Riff Raff
- 4:24 PM
- Jan 8, 2016
- Franklin, OH
That is atrocious!
I wasn't super concerned about it, just wasn't sure about it at the bottomThe intake skirt looks totally normal.
Thought you might like to gander at a screwed up saw that didn't come from jmsFancy.
Yeah I measured one of my good ones right at that 289 mark, this jug was right around 190That corner is thinner normally. They used a cut off wheel or end mill burr like you said to work the uppers. The corner with the square corner is normally about .289" from my notes and had one at .312" with 7 jugs I have notes on.
It would take some work for sure,if they ain't to high all ready to clean them up......[emoji106]Those upper transfers are a train wreck. That cylinder is pretty much garbage unless a person wants to invest a lot of JB weld.
Guy said it ran great but I went in for a preliminary inspection and I found some questionable things, so I went ahead and tore it apart. I couldn't get a spacer made for my timing wheel so I tore it apart without getting numbersFlywheel is still usable. I'm curious what the timing numbers are on that jug? How well did it run?
I'd slap it back together and run the piss out of it. What do you have to lose??Guy said it ran great but I went in for a preliminary inspection and I found some questionable things, so I went ahead and tore it apart. I couldn't get a spacer made for my timing wheel so I tore it apart without getting numbers![]()
True very true, It would just bug the hell out of me knowing it is like thatI'd slap it back together and run the piss out of it. What do you have to lose??
I may have to take you up on that, I have a 2165 I'm building for 3 cuts at a time so I may put this flywheel on it and get another one for this oneI think I have a flywheel for you if you want or need it.
Understood.True very true, It would just bug the hell out of me knowing it is like that
