It's Stihl 044 time
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
Back to it.
I bolted in the oil pump.
Thought I took a pic, evidently I didnt.didn't..
I turned the oil tube to the side for access to the case bolt behind it for later..
I set it on boards because of the tube.
And threw some heat too it.
20230318_102013.jpgpushed the bearing in (shoulder facing out)..
And gave it a couple taps to be sure it was seated with my special tool..
I put a little more heat to it and the crank dropped in.
Couple light taps made sure it went in.
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
Now to the flywheel side.
One dowel was slightly pushed in, 1 pulled out.
Hammer and punch and I re-entered both.
And heated it up
And pushed in the bearing.
Couple taps with same piece of pipe I used on the other bearing to make sure it's seated.
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
Here I use a light smear of anaerobic sealer on both sides of the gasket.
I don't think it's necessarily required, but my thought is in an event the case bolts were to loosen up the gasket being adhered to both cases would keep it from having an issue.
Maybe it's just a waste of time.
I line it all up, and start the case bolts.
Some taps here and there, and turning all bolts evenly, it pulls it all together.
Member
1:12 AM
What's the general consensus on this?
My small mind is thinking by looking at it there's a chamfer on the back of the sleeve so installation would go- seal into bearing, sleeve into seal.
Yes? No? GFY?
Yes, install seal then grease up the sleeve and twist and push and it will slide right on. Grease the shaft too.
2:12 AM
Yes? No? GFY?
That’s how I do it
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
The oil pump can go on
There should be an o ring under the tensioner.
I had one from the MS460 I just did that had 2, but damned if I can find where I put it, so I'll just carry on without for now
Tensioner, thrust block, and tighten the screw.
Install the brake lever, E clip and spring.
Make sure the spring is oriented correctly. If not, you'll see it push the lever away from the case.
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
A piston was procured in a deal with a man with sausage hands who lives in a mitten. (Can't just make this shìt up)
New pin bearing and some mix oil
Piston installed with the clip opening at the 6 o'clock position.
And there it is.
I've got more stuff on the way for it and cleaning up of other components yet to do so back to slacking.
redline4
I'm huge in Japan
1:12 AM
Rosholt Wisconsin
The front handle was pretty tweaked.
I tried some heat, bending, hammering, bìtching and more heat.
It ended up kinking in multiple spots, I can't get the shape near correct or it to line back up..
So I'm going to use one I already had from an 046.
I'm planning to re-cover it because it was pretty worn down.
I ordered some non slip shrink tube meant for fishing rods.
It was cheap enough I thought it was worth a try. It should be here next week.
jacob j.
Only the weird
11:12 PM
Coastal Oregon
Yes? No? GFY?
That's how it is listed in the service manual.
