It's MS461 Time In Tennessee
cus_deluxe
terms of service violator
12:12 AM
Michigan
heck, it wasnt that long ago that an oz of weed would land you in prison here. now i can drive around with an oz in the glovebox (if i chose to, which i dont). lots of folks doin time for BS. but the fraudsters can suck one, those are the ones who need to get nailed
Wonkydonkey
Plastic member
4:12 AM
Sussex, UK.
If I lay the saw on its side I get 6793g
And if it’s upside down 6795g
I guess my wobbly scales lied to my sleepy head
There only kitchen scales
I hope there not lying to me now.. :rolleyes:
Bigmac
9:12 PM
Interesting on the universal Stihl coil , 026-044 coil, I thought that the poly flywheel coil was needed for those models. Apparently it’s not a problem? Or is there any other mods needed? I thought the poly coil had a start retard, is that the only downside to the 1300 coil? If so dose it make sense to just lob of the bottom leg on the 461 and advance the timing for it?
qurotro
Cookie Cutter
11:12 PM
Ar
Hm....The point is 461 coil is limited.
11:12 PM
Only difference I've seen is that the 1300 coil has no retard for starting. Even with 6 - 8 degrees of advance that's never been a problem.
Cutting the bottom leg off of the 461 coil does nothing. We heard that rumor years ago, and proved it to be untrue.
At one time I used the 460/660 coil, but they've become harder to find used, and are pricey new.
12:12 AM
What carb comes stock on this 461?
