It's MS461 Time In Tennessee
9:23 PM
Is it beneficial to keep port timing with a pop up but its more work? Or is the changed port timing from milling the cylinder not noticable?
Many times I'm looking for a lower than factory exhaust duration. I realized how much that can help certain saws years ago by reading stuff that my peers had written. So, over the years I've tried this approach on a great many different saws with good results. For instance, on the 461, I use 105 on the exhaust port. 103 is the factory opening point. That's not possible with a popup.
pwheel
Finis Origine Pendet
10:23 PM
MA
Bring back the 044/ms440
The ms461 introduced improvements such as: no sleeve on the pto side of the crank, the oil pump design eliminates the tube which is a pta to service, the shroud connectors are less prone to stripping, and the baffle inside the air filter is a better design than the foam insert. Still keeping my ms440's, though.
9:23 PM
Another thing to consider with a cut squish VS a popup.....
The squish band is a cast surface from the factory. The clearance varies.
Once it is cut, you have a machined surface facing another machined surface, so the clearance can be set tighter, and squish velocity is increased.
Does this matter in overall power? I'm not sure. I do believe it helps quell detonation.
Nutball
9:23 PM
Mt. Juliet, TN
How many cylinders per alumihog burr? At the rate it sounds, do you save them and sell them as scrap or send in for bulk resharpening after a year or few? Both options would seem money saving/profitable in my opinion if you go through a ton.
Also, do they last suck a short while because you cut the cylinder plating with them? I just can't bring myself to cut the plating with carbide unless I have a starting point and cut from under it. Otherwise 8 use diamond burrs, then my carbide last a long time.
Ive also had a hog burr go dull really fast on plywood, and it was new too. That or they didn't send me a sharp one.
9:23 PM
6 - 8 jugs probably. Once they get a little dull, I use them for the uppers. That gets me a few more days worth from them. Then I use them on mufflers. After a few mufflers......they ain't worth anything. LOL
kneedeepinsaws
8:23 PM
Oil Country
Thank you for explaining that!
9:23 PM
9:23 PM
Lol. At least there ms461s only problem is by the time you get finished with all of them you probably won't want to see another one for a while.:eyepop:
Found another one after I took that picture. Ended up with 9. I'm still working on the machining.
Deets066
AKA Deetsey
10:23 PM
You must have changed recipes? I believe the one you did for me is 102
