Terry Syd
- 7:43 PM
- Jan 18, 2016
- Comboyne, NSW Australia
I'm thinking if one were to manually press the metering diaphragm for a moment it would provide a prime of fuel through the main nozzle from the pressure that builds in the fuel tank.
If the tank didn't have any pressure, it might still work. Pushing on the diaphragm will lift the metering valve, but the reed valves on the PUMP diaphragm should keep the fuel from being forced back into the tank. The fuel under the diaphragm would then be forced out of the carb and into the engine.
