Hyway 461 cylinder swap
SixGun
7:07 PM
Hackettstown NJ
Swapped out a 461 cylinder with a new Hyway kit.
Old cylinder was perfect inside but customer failed at installing a thread insert and reemed it out badly.
I promised Randy I would do a thread so I took a bunch of pics while doing the swap .
Nothing special but everyone loves pics.IMG_0536.jpg IMG_0537.jpg IMG_0535.jpg
SixGun
7:07 PM
Hackettstown NJ
Bore measured exactly the same, I left the OEM piston.
I didn't check timing as I am in the process of moving my shop and things are crazy
SixGun
7:07 PM
Hackettstown NJ
IMG_0539.jpg Piston before cleaningIMG_0544.jpg After cleaningIMG_0543.jpg First I carefully scraped heavy carbon from piston with a razor blade, then I use PB Blaster on a scotch bright pad to polish off the staining, Do this with the saw laying on its side so as to not get carbon into the case
angelo c
Coal Member
7:07 PM
lemme know if ya need a hand and a truck.
their both old and rusty, but they can fool the sharpest eye into thinking they were worth the beer.
SixGun
7:07 PM
Hackettstown NJ
IMG_0540.jpg 460 cylinder left and 461 on the right IMG_0541.jpg Un-portedIMG_0542.jpg Ported. Just some comparisons for anyone interested.
SixGun
7:07 PM
Hackettstown NJ
Thank You for the offer!
I've been doing little by little and making OK progress so far.
I will take you up on that beer sometime though
SixGun
7:07 PM
Hackettstown NJ
Also get some oil in the cylinder and a little grease in the intake boot
SixGun
7:07 PM
Hackettstown NJ
IMG_0550 (1).jpg NubbinIMG_0549.jpg The nubbin in pic #1 is keeping the muffler from seating properly. Lesson learned- Trim Nubbin before installing cylinder.
SixGun
7:07 PM
Hackettstown NJ
IMG_0552 (1).jpg Stock Nubbin rests against muffler perfectlyIMG_0553 (1).jpg AM Nubbin needs to be trimmed quite a bit. Glad I didn't keep cranking the muffler screws in. I personally think that this is done on purpose because of Stihl design protection and patent type stuff.
SixGun
7:07 PM
Hackettstown NJ
OK to summarize:
The new Hyway cylinder is very nice and well built.
The plating and bevels were very nice and casting flash was minimal .
Fitment was good overall except for the nubbin.
Nubbin was an easy fix and muffler bolted up perfect after grinding.
Saw fired up on first pull and tuned well.
I am very happy with this cylinder and would definitely run one on my own saw.
SixGun
7:07 PM
Hackettstown NJ
Just checked squish with gasket and it's right at .028. Not bad at all
Checked a Stihl gasket and it was .034 so I'm gonna say negative on the gasket delete unless you cut squish or replace gasket with something super thin.
Dieselshawn
7:07 PM
Southern Ontario, canada
Sixgun: I did a piston and cylinder with a hyway kit for a 440 for a customer.
I gave him options of a Stihl OE kit or the Hyway for half the $$. He chose the Hyway kit. Customer was at the point of getting a new saw if he had to buy the Stihl kit.
Seems to be a decent kit as you've described.
Saw started and tuned easy. Demonstrated to customer, he was pleased and haven't heard back from him in a while. Last I was told the saw is running well.
SixGun
7:07 PM
Hackettstown NJ
No problem Randy.
Hopefully soon I'll have time to do a cool build thread with some porting and stuff.
