HUSQVARNA HUSQVARNA THREAD
Bryan Barrow
1:44 PM
From Plainfield, CT to Black River, NY
Well my excitement got the best of me. Here’s my advice based off my experience (394xp cylinder. Risked a lot and trusted my research lol)
1. 1 tbsp dish soap per liter of water
2. Set to 130° (55° Celsius)
3. Run for 10 min, flip, then another 10 min. Not sure if flipping helps but it makes me feel better
4. Immediately rinse it all and dry with a hairdryer on high until complete (I don’t have an answer yet for when your wife/girlfriend finds out)
5. Do it all again
Dawn dish soap won’t corrode or discolor the cylinders and does a pretty phenomenal job. I’ll add photos. I should’ve done more prep getting chunks off but I’ll own that one. I was impatient and just wanted to get it in
singinwoodwackr
11:44 AM
moon
Which US did you get?
my little one is 20yrs old and about dead and the larger one, estate sale for cheap, doesn't work all that well.
Junk Meister
12:44 PM
Nebraska
I kind of cheat and dip the cleaning solution (Mostly simple green) out of the USC tank and nuke it hot. saves time and I have heard the heat part a the weak point Others say the drivers get weak.
Bryan Barrow
1:44 PM
The Central Machinery 6L from harbor freight. Had good reviews. Now we’re trying it out on her ring
Maintenance Chief
1:44 PM
South Carolina
5. Do it all again
As far as building a saw ,I have a 394xp in great condition and it's a fun saw to run!
I've never sweated the plastic parts for a cheap build .
Crank,cylinder, carb,piston, and case if salvagable ! I've built 2 066's out of scrap yards and they have aftermarket parts like covers,recoils,and fuel tanks.
If you want to build and run a 394xp, just get it done!
Bryan Barrow
1:44 PM
I can probably find someone to weld the 3rd clutch cover but I’m stumped on the first two
singinwoodwackr
11:44 AM
moon
Yea, that 2nd one is missing a bit :p. If you have another that is broken but has that section intact you can make it work.
That said…finding someone to weld magnesium other than yourself or a cheap friend will not be cost effective. Just the rod is $150/#
Bryan Barrow
1:44 PM
I hadn’t looked that much into it. Definitely not then. I’ll just call it a crop top clutch cover
Partner
7:44 PM
Poland
I made a thread of my own called “Husqvarna 3-Series lot build” that way I don’t hog this up with my updates if yall wanted to follow along
I am a supporter of one husky thread, but Magnus's and there are a million of them 😉 where can I find your huskies?
singinwoodwackr
11:44 AM
moon
Anyone have a trick for removing the seal caps from the 350 bearings?
