HUSQVARNA HUSQVARNA THREAD
Bryan Barrow
8:58 AM
From Plainfield, CT to Black River, NY
Well my excitement got the best of me. Here’s my advice based off my experience (394xp cylinder. Risked a lot and trusted my research lol)
1. 1 tbsp dish soap per liter of water
2. Set to 130° (55° Celsius)
3. Run for 10 min, flip, then another 10 min. Not sure if flipping helps but it makes me feel better
4. Immediately rinse it all and dry with a hairdryer on high until complete (I don’t have an answer yet for when your wife/girlfriend finds out)
5. Do it all again
Dawn dish soap won’t corrode or discolor the cylinders and does a pretty phenomenal job. I’ll add photos. I should’ve done more prep getting chunks off but I’ll own that one. I was impatient and just wanted to get it in
singinwoodwackr
6:58 AM
moon
Which US did you get?
my little one is 20yrs old and about dead and the larger one, estate sale for cheap, doesn't work all that well.
Junk Meister
7:58 AM
Nebraska
I kind of cheat and dip the cleaning solution (Mostly simple green) out of the USC tank and nuke it hot. saves time and I have heard the heat part a the weak point Others say the drivers get weak.
Bryan Barrow
8:58 AM
The Central Machinery 6L from harbor freight. Had good reviews. Now we’re trying it out on her ring
Maintenance Chief
8:58 AM
South Carolina
5. Do it all again
As far as building a saw ,I have a 394xp in great condition and it's a fun saw to run!
I've never sweated the plastic parts for a cheap build .
Crank,cylinder, carb,piston, and case if salvagable ! I've built 2 066's out of scrap yards and they have aftermarket parts like covers,recoils,and fuel tanks.
If you want to build and run a 394xp, just get it done!
Bryan Barrow
8:58 AM
I can probably find someone to weld the 3rd clutch cover but I’m stumped on the first two
singinwoodwackr
6:58 AM
moon
Yea, that 2nd one is missing a bit :p. If you have another that is broken but has that section intact you can make it work.
That said…finding someone to weld magnesium other than yourself or a cheap friend will not be cost effective. Just the rod is $150/#
Bryan Barrow
8:58 AM
I hadn’t looked that much into it. Definitely not then. I’ll just call it a crop top clutch cover
Partner
2:58 PM
Poland
I made a thread of my own called “Husqvarna 3-Series lot build” that way I don’t hog this up with my updates if yall wanted to follow along
I am a supporter of one husky thread, but Magnus's and there are a million of them 😉 where can I find your huskies?
singinwoodwackr
6:58 AM
moon
Anyone have a trick for removing the seal caps from the 350 bearings?
