- 9:53 AM
- Apr 5, 2024
- Wyoming
What a dream saw
What a dream saw
Thanks, a favorite cord wood saw .What a dream saw
I found a Husky 136 at the dump missing the clutch cover, recoil and has a scored piston and possibly some scoring on the cylinder, but found it worthy to bring home and revive. I figured if anything it could be the "loner" saw when someone comes and asks to borrow one!Is it worth any time/money to try to revive one? It's free to me.
I probably have some parts for you if you get me a list or maybe you can have the whole boxI found a Husky 136 at the dump missing the clutch cover, recoil and has a scored piston and possibly some scoring on the cylinder, but found it worthy to bring home and revive. I figured if anything it could be the "loner" saw when someone comes and asks to borrow one!![]()
I'm going to the wrong damn landfill...Got a family picture of the all of the Husqvarna's I have:
Front to back:
* 136 (dump find)
* 440 (well used store loaner saw)
* 55 Rancher (dump find)
* 455 Rancher (customer returned to store - said "was a piece of junk")
* 272 XPG (dump find)
* 2100CD (dump find)
That list didn't include the 046 or the plethora of Wildthings that were there too!!I'm going to the wrong damn landfill...
Gents, I have 'opportunity' to take possesion of a somewhat whooped on 543xp. It's rough and not making much air. Ex side of piston looks fine but I'm only seeing ~50lbs on the guage. It's got a broken flag, bent handle and the on off switch is wonky. Does make spark. No joy with some gas down the plug hole.
Husqvarna thread is not too active here but I will ask anyway...customer brought in a 240 that he only uses occasionally, as in once or twice a year. I went through it last year with fuel lines, fuel filter, carburetor kit and it worked fine for me but he says it dies after making a cut. He is using canned fuel and it looks and smells good.
I ran it until it was good and warm and tried snapping the throttle off after running WOT and sure enough it would die. I tried adjusting both H and L a bit leaner assuming it was too much fuel but it did not cure it completely.
I went through everything on the saw, compression is 150 PSI hot, crankcase holds pressure and vacuum just fine, carburetor holds 12 PSI, I can't get much more out of my squeeze bulb tester so I don't know where exactly it might pop off.
He needs it this weekend so I am sending it out the door but expect it will come back again. What else should I be looking for? FWIW, it always restarts in a pull or two if I put it in the fast idle position, reluctant to restart after dying with the throttle at idle.
I did look through the carburetor again, everything is clean, diaphragms are pliable, inlet screen is clean.
Mark
Tank venting issue, thought still weird because it restarts on fast idle. Maybe it thinks it’s a 562 mark 1.Husqvarna thread is not too active here but I will ask anyway...customer brought in a 240 that he only uses occasionally, as in once or twice a year. I went through it last year with fuel lines, fuel filter, carburetor kit and it worked fine for me but he says it dies after making a cut. He is using canned fuel and it looks and smells good.
Mark
Try ditching the canned fuel. Some of that stuff just doesn't have enough "pop" to it.Husqvarna thread is not too active here but I will ask anyway...customer brought in a 240 that he only uses occasionally, as in once or twice a year. I went through it last year with fuel lines, fuel filter, carburetor kit and it worked fine for me but he says it dies after making a cut. He is using canned fuel and it looks and smells good.
Mark
I'd check fuel and air filter and look for any kinks in the fuel line. I sounds like the carb isn't pumping enough fuel at idle. Some aftermarket fuel filters look OK but get restricted over time.
I'm not sure if the fuel line on those is made from the tygon looking stuff with the liner inside that sometimes collapses.
Then check and tune the relationship between the Lo and idle speed settings. If they are off and one is compensating for the other in speed, can cause the issue you describe.I replaced the fuel line last year with the good stuff from Echo. Fuel filter is clean, it behaves more like it it too rich after a cut. I did lower the metering lever just a bit when I had it apart.
We'll see.
Mark
