HUSQVARNA HUSQVARNA THREAD
heimannm
2:52 PM
Dike, Iowa
Got it.
We'll see if this guy wants to spend any money to make the saw right. It actually runs pretty well with the scored piston and 130 PSI compression. I can't imagine trying to start it with 180 PSI...
Mark
2:52 PM
eric4
12:52 PM
Northern CA
I'm assembling a 550xp mk1 from a recent build, and seem to be having some clutch trouble...
Doesn't seem to be free-spinning and I did grease the needle bearing. It looks like the drum is properly seated into the oiler worm gear, but once the clutch is locked down, there's no drum free-spin...
Revisiting the parts diagram, I don't see any sort of missing washer, but maybe y'all can give me some tips?
2:52 PM
The "star" on the clutch drum has to fit in the oil pump worm gear corresponding receptacle. If askew it will do what you're experiencing.
president
12:52 PM
peachland BC Canada
eric4
12:52 PM
Northern CA
Yeah I dropped the drum into each 'star' indentation, and it never sunk quite low enough to clear the clutch
I'm not even sure if it was properly operating when I got the saw, as it was a 'parts' deal.
Feels wrong...but if I just ground down the drum tabs that drop into the worm gear a millimeter, it would clear the clutch
hacskaroly
2100 Fanclub Member
12:52 PM
Northern Idaho, Ehh
Does anyone have the length of the muffler bolts for the 2100CD? I believe they are M6 100 pitch bolts.
hacskaroly
2100 Fanclub Member
12:52 PM
Northern Idaho, Ehh
Damit…now I’ll have to go out and measure for you, lol…
Wow, that was quick!! Thanks! I was looking for a socket head at the store today, forgot they were hex heads, I may have to take another look. I was working on my 2100 today and realized I was missing some of the smaller M5 80 bolts that hold the body into the AV mounts, so went and got those.
Woodwackr
1:52 PM
ID
Woodwackr
1:52 PM
ID
Opinions?
562xpg, XS ported, scored but not bad from the pics (don’t have the saw yet)
I’m hoping just the piston and ring will need replacing. Question: strictly oe or is the Meteor a good one on this model?
Piston price is damn near that of the full top end kit for oe.
Pro faller’s saw
FergusonTO35
3:52 PM
Boonesborough, KY
Opinions?
Pro faller’s saw
My question would be, if the guy is a pro why doesn't he just fix the saw and keep using it? May be other things wrong with it on top of that. In any event it probably has alot of hours on it so may not be such a good deal even with you doing the repairs.
Woodwackr
1:52 PM
ID
He has asked me to fix it. I'll know more when it gets here. Since it is a ported cylinder I'm hoping just the piston/ring will need replacing. if bearings are needed they will get replaced as well.
First thing to do is figure out what killed it…
