- 2:30 PM
- Jan 28, 2016
- Dike, Iowa
There are many YouTube videos of plastic welding, some are even helpful.
Mark
Mark
If the 262 cleans up well and runs good, maybe $400. For me the 36 would go in the trash, but I’m sure someone will disagree.A local guy dropped off a couple of saws today, says they haven't been run in a while...
The 262 seems to have great compression, the 36 not so much. His idea is I get the running and he will sell them. Just curious about the value of these all cleaned up and fully operational before I put the time and effort into them.
Mark
$100, all fixed up on the 36. They make great little camp sawsA local guy dropped off a couple of saws today, says they haven't been run in a while...
Mark
I don’t think you are off base unless you are wanting to work for free.Update and hoping for more input...the 36 has about 125 PSI compression and O.K. spark. Slight score on the piston is visible through the exhaust.
The 262 has 150 PSI compression and good spark. Piston looks good through the exhaust port.
I expect it would be 2-3 hours to tear the 262 down for a thorough cleaning and inspection, replace the lines, carburetor kit, other bits as needed.
It might be possible to sell the saw locally for $300 but frankly, I don't have many folks looking for "bigger" saws around here, most want smaller and lighter.
I'm thinking of offering him $150 for the pair as is and go from there.
Am I off base???
Mark
If the 262 has a good oe carb, I'd go $200 for the pair.Update and hoping for more input...the 36 has about 125 PSI compression and O.K. spark. Slight score on the piston is visible through the exhaust.
Am I off base???
Mark
Is the carb an 81 attached to a KS cylinder? If so, my stock 262 was 170psi and I only ran it for 20 years and sold it for $500. I would give him $200 for it, if it's a KS, clean it, new ring, vacuum check, open muffler and pop can gasket.A local guy dropped off a couple of saws today, says they haven't been run in a while...
Mark
PB blaster?I will have a closer look at the carburetor and cylinder tomorrow and report back.
Meanwhile...does anyone know if there are alternate crankshaft seals for 503260601?
Also, I am having trouble getting the oil pump off, seems like the chip guard/washer is stuck to the crankshaft and won't let the pump come out.
I'm sure there will be a few more parts inquiries/saw questions to follow.
Mark
