HUSQVARNA HUSQVARNA THREAD
jacob j.
Only the weird
2:42 PM
Coastal Oregon
farminkarman
I like the red & black ones
4:42 PM
Neenah Wisconsin
I’m not sure there is anything wrong with the carb & coil…could be I suppose. It would be all be good if the AT could lean out the low circuit. I’m sure it was at max fuel based on the seals or lack thereof when it had last run. It seems like the AT already cleaned up the high circuit….just pig rich on the low side.
I ended up taking the saw into my dealer and had him reprogram the coil to match the carb and do a firmware update. The saw is running good now.
redneckhillbilly
3:42 PM
NW MT
572 fuel tank replacement, how hard is it? I keep my saws in a truck tool box and they do bounce around alot, I'm thinking it must have bounced and landed on a nut or bolt or something.
redneckhillbilly
3:42 PM
NW MT
I've never tried to weld plastic before and did think about trying it out, had some seals all epoxy that is made for plastic gas tanks and cans I put on there. I know there is a clapped out 572 at the local husky shop I just a few days ago, it has a couple balls missing from the PTO bearing, I am gonna try to buy the tank from it next week.
qurotro
Cookie Cutter
4:42 PM
Ar
I haven’t had good luck with plastic welding. Id bet I just don’t have the right tools and knowledge. Got any vids of the procedure along with the necessary tools?
A solder iron with adjustable temp would help. You need to try it by slowly increasing temp, find the sweet spot.
