HUSQVARNA HUSQVARNA THREAD
Steven1210
3:27 PM
uk
Hi there guys. Im in the uk. Do any of you guys have any info or part numbers for the connectivity device? Fits to a 592xp?
calcutta250
10:27 AM
SC
Question all. Looking for the spring assist start that 545 has to add it to the 550xp.
Do you all know a reputable internet store that has the kit in stock.
Is there a reason not to add this kit to a 550. I can pull it over I just don’t want more effort than required.
Thanks!
Squareground3691
10:27 AM
New England
Thanks!
Just curious, is ur 550 that hard to pull over ?
calcutta250
10:27 AM
SC
I don’t have the saw yet. I start my 50-90cc without using the decompression buttons. When I’m exhausted the extra assist might be nice.
More so I just want to try it out.
Duce
10:27 AM
Roscommon, MI
You will not need it. Saw starts easy and restarts are a nonissue. No decompress on 550 mkII. Enjoy your new saw.
calcutta250
10:27 AM
SC
Get urself some Stihl .325 RS PRO chain it’s pretty sweet stuff,
I’ve already bought two. I had bought one earlier for my echo 4910.
I hate to ask this but when you grind do you take the wheel to the gullet area or stop it before that for the C shape people like.
I cut hardwood so Im considering 60° and 25°.
calcutta250
10:27 AM
SC
Thanks!
@Spike60 will know the part number.
Squareground3691
10:27 AM
New England
The Pro chain has basically very little gullet new , haven’t found a faster chain , and do a duel port on that 550 , there way toIMG_1846.jpeg resticked from factory, if your not worried about warranty,IMG_1193.jpeg
davidwyby
Rural desert logging
7:27 AM
Extreme Southeast CA
I would try to maintain stock angles
heimannm
9:27 AM
Dike, Iowa
I was running my 345 again this week and found it wasn't oiling. Checking it over I found the plastic worm gear on the piston was damaged, no big problem as I have a couple of spares on hand. Replaced it and it is oiling correctly again.
This is the third or fourth time it has happened with this saw that doesn't really see a lot of hours of operation (it is a loaner saw from time to time...) Any idea why I keep having this issue and what can be done to fix it for good? I did find a bit of sawdust behind the inner chain guide plate but it seems to fit nicely and doesn't have any holes in it.
Thanks for your input.
Mark
GerbrandR
4:27 PM
The Netherlands <-> Austria
Mark
Not sure how the oiler on that saw looks like. But I had a Jonsered 2171 that was used with some real sticky kind of bar oil. The gear inside the oiler was very hard to move and it I had the same happening as you.
Otherwise I am not sure what can be the cause.
