HUSQVARNA HUSQVARNA THREAD
Partner
11:23 PM
Poland
Will the top end /p&c/ and the flywheel from Husqvarna 444 be suitable for Husqvarna 44?
CJ Brown
5:23 PM
Belleville, Ontario, Canada
Be careful with the flywheel. Some had two keyways and you have to match the keyway to the coil you are using. The keyway with a "P" stamped beside it matches the blue prufex coil. The other keyway is for all other coils and also points type ignitions.
Partner
11:23 PM
Poland
Yes the coil is blue, thanks / I also noticed that the dogs on the flywheels are different, so the starter is also needed with H444
Partner
11:23 PM
Poland
the saw runs backwards after a while and before it is demolished I will check if it is the fault of the ignition coil or incorrect installation of the flywheel
GerbrandR
11:23 PM
The Netherlands <-> Austria
There is a 365 Special for sale, local to me. Never been used.
Not sure about the price, it's not crazy high but not a bargain either. What would be a reasonable price?
I do have a 50 and a 51.4 mm cylinder kit for a 372. If I am not mistaken, they are a direct swap to the 365 cylinder?
qurotro
Cookie Cutter
4:23 PM
Ar
Yes. But depending on what 365 jug is has. Some 365 with open port jug, then you will need a intake manifold. Not a big deal.
Partner
11:23 PM
Poland
The spring didn't get there by itself, someone helped her. Are sealants available? There is also no o-ring, you don't want to see p&c
Partner
11:23 PM
Poland
looks like time for bearings
Bearings have no clearance, probably because they are dirty .
It looks like someone glued a seal, the lip is on the outside . The o-ring is in the cover here, it was hidden under the dirt
Partner
11:23 PM
Poland
Someone warned me of my intention to put in 44 p&c of 444 , the saw ate this set
5:23 PM
I've seen around 700.00 usd for new 372xts
The 365s were around 650.00 iirc
It just depends on your market.
thedude74
Bonafide & Stuff !!!
2:23 PM
Alaska
There's a 365 special at the local pawn shop for $475... ..but it looks like it's been drug behind a truck on a dirt road for several miles🤣 Completely beat to chit.
