HUSQVARNA HUSQVARNA THREAD
Wolverine
dilligaf
9:26 AM
The 365 a guy gave me is in pretty good shape ,
Rubber mounts have been the DEVIL to find
Bar was bent on it, so a new bar and chain is needed , what length you use??
Sent from my SM-G955U using Tapatalk
Nice! A Special. I use a 24 on the one I have. Handles good and oils it just fine.
xsoxso
2:26 PM
Germany
Painting done. The color matches the husqvarna orange quite fine. Only the Paint layer via brush did not turn out as well as i would have liked it :(
Maintenance Chief
9:26 AM
South Carolina
Maybe someone else has run into this ...
Put new seals in the saw, intake sealed up tight, but when I put pressure on the spikes or bar and lift up on the handle she leans out? Can the fuel line get pinched?
M2theB
9:26 AM
Central Mass
AV mounts soft? Could be throttling up when the tank and case is hinged.
9:26 AM
does that one have the big bore? Im looking at rebuilding a parts saw 346xp.
Usually the 346’s with the silver side cover, grey clips and primer are “NE” editions with the factory “big bore” 44.3mm cylinder. Unless someone changed those parts already.
JBW1
7:26 AM
New Mexico
cool, thanks. What I was wondering, was if he had it stock or slapped a 45mm in.
heimannm
8:26 AM
Dike, Iowa
Does anyone have experience with the Holzforma version of the 372? Someone gave me a new one to use and after a couple of outings the throttle cable is trashed. I was wondering if an original 372 used a similar cable so I can upgrade this saw.
Thanks,
Mark
p61 western
Ol Mudflap
6:26 AM
GFY
Thanks,
Mark
Yep a oem 372 cable will work fine. I had the same problem.
9:26 AM
Thanks,
Mark
Yes same as oem.
Could you get a pic of the fuel and pulse line's
At the carb
In front of the choke.
PogoInTheWoods
9:26 AM
Ohio
Rich Dougan has a video that shows how to change that cable in five minutes -- if you've already done a dozen or so. Still worth watching to demonstrate that it can be done in five minutes or less. LOL The second vid by the other guy shows what Rich is actually doing inside the handle with the cable and the trigger.
heimannm
8:26 AM
Dike, Iowa
Excellent gentlemen, thanks for all your assistance.
The second video is almost "Bob Ross" like...
Mark
