Husqvarna 576xp - FixerUpper
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
I have cleaned and reassembled the carburetor and the intake boot setup.
Since I found the saw already disassembled, I have to keep referring to the IPL and prefitting everything to make sure I get back together correctly.
First connection made, the screws are in there temporarily to hold them together and make sure everything actuates correctly.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
Next, working on the air filter elbow and choke/stop lever, all parts are there, but really dirty.
I don't have a nozzle for my air compressor to blow all of the crud off, so I take my time with a screw driver, de-greaser, q-tips and paper towels. While time consuming, the stuff looks pretty good in the end.
Final assembly of these components to the carb. I can't find the two shorter screws that connect the two, so I need to check the IPL and see what I can find that might work. Otherwise, so far everything is matching up and working properly.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
Next up is the recoil assembly. I have found so far if the saw is grimy, then it is very likely the recoil spring has some gunk in it, making it harder to recoil or stop recoiling all together. While not as bad as some others I have worked on, this one had some stuck on grime.
I left the pull rope attached because it is in good shape, just a bit dirty. I took the rest apart to give it a good cleaning.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
I found one of the dollar stores has a box of 300 cotton swabs for $1.25, so I got a few boxes, they sure help when getting into the nooks and crannies! Helps get most everything without the luxury of an air compressor!
The spring went back in fairly easy, though I did have to pull it out, mate it up with the starter pulley assembly and then reinstall it.
With the pull starter back in, it snaps back into place now when pulled. Sure makes a difference cleaning out the spring.
With the air conductor back in place, this assembly is ready to go back on the saw.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
At this point I decided to remove the Carburetor Area Base plate, however I ran into an issue with the wire that leads to the coil. I tried to feed the wire through the hole it comes through and the connector would not fit. The wire leads behind the flywheel and is fitted in a plastic trough, so I could not pull it through that end. At this point, I had to remove the flywheel to get the wire out.
I recently bought a flywheel puller, but in accordance with Murphy's Law, does not fit this flywheel. I resorted to loosening the flywheel nut and then used my blacksmith hammer, gave it a few taps and the flywheel came off.
From here, I was able to get the wire worked out of its groove and the carburetor area base plate removed for cleaning.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
First step before cleaning is to take everything off that can come off.
During the cleaning, I removed the dirt from around the wire and found that there is enough room to slide the wire out...so there is a way to take off the carburetor area base plate without having to take off the flywheel. No worries, the flywheel needed to come off for cleaning anyway! With the carb area plate and its associated parts clean, I put them in a box while the rest of the saw gets cleaned.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
Next up, I worked on disassembling the clutch and chain brake assemblies. Not too bad looking with the clutch cover off.
Removed the chain brake cover and pulled the main spring.
Pulled the rest of the chain brake assembly.
I tried to get the clutch off, but am having issues. I immobilized the piston rod. Unfortunately I don't have a clutch puller that will fit this clutch. I tried using a screwdriver on the edge detents to knock it free, but it didn't work. I am thinking I will need to put the piston and cylinder back on and put in a piston stop/rope and give it another try. I decided to separate the fuel tank at this time too.
Dirty clutch cover and parts.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
Clutch cover and associated parts are cleaned, needle bearing will be greased before re-installation.
Looking at the rim sprocket, what is a good way to tell if it is ready to be replaced when looking at it? I know Stihl recommends changing them every two chains, but what is your practice?
Next up is the chain brake assembly....dirty image first:
Parts after cleaning. Will have to wait until I clean the main body to put them all back in.
Squareground3691
8:04 PM
New England
I’ll say one thing, 576’s are silky smooth 👍
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
That one will run awhile longer.
Thanks, I have not run a saw long enough to have to change one out yet, but have seen a few come in the shop that were obviously ready for a change, especially those that converted from a one piece rim to a two-to-three piece rim...
I have felt the drivers on chains start to get really rough when a chain is run loose or a rim is worn out. They are fairly cheap enough to not have to run them to the very end to milk every cent out of it.
beaglebriar
The Peanut Gallery
8:04 PM
Warren Center, PA
In my opinion you have to pull that clutch and check the crank bearing for play. The bearing pocket on these saws are known to fail on the clutch side. You can butcher up a one inch deep well socket or similar to make a clutch puller or find something about the right diameter and make one. The one I have is made from a large wrist pin. Hit it with an impact and it’ll come off, no need to reassemble. Hold onto the rod, I usually wear a glove cuz it’ll wanna pinch your hand.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
Pics for reference. If you have access to a mill this will be easy. I made mine with a death wheel in a 4” grinder iirc… It’s been awhile. Or buy one but what’s the fun in that?
I appreciate the reference photos. Unfortunately I do not have access to a mill, I will have to look for another way, maybe with an angle grinder or something. That does give me a better idea what I need! I am definitely going to get the clutch off before this all goes back together, just getting off all the crap on the outside, so there is less chance of it getting around the crank. The last 372 I worked on had issues with the crank going around, come to find out when someone else took off the cylinder, they knocked some junk in there and apparently there was a 1/2" long piece of metal that got in there and prevented the cylinder from going around. I flushed it a couple of times with mix fuel and it finally washed out and the crank could spin freely.
Maintenance Chief
8:04 PM
South Carolina
I made my clutch removal socket with a 4.5" grinder/cut off wheel.
I jamb a wooden dowel, plastic handle,rope,rag, or whatever into the crankcase to hold the crankshaft while removing the clutch. A scrench through the wrist pin resting on some blocks works to.
I've taken a big adjustable wrench and closed the jaws in the clutch and turned it off with another adjustable wrench too.
hacskaroly
2100 Fanclub Member
5:04 PM
Northern Idaho, Ehh
I made one myself as well, but the clutch was so tight I couldn't get it to work.
Ended up losing patience and hitting it with a punch and a hammer. Damaged more than I should have.
Then I ordered the official clutch tool and it really works the best for me.
I might have to try the adjustable wrench trick...but in the end I might be best off buying the actual tool...depends on how badly I scrape up my knuckles in the process...lol.
