Husqvarna 564xp (g) fuel inject
cuinrearview
Handy dood
10:36 PM
Dowling, MI
No I just like the way they handle and feel.
I don't care if a saw gets pinched, we have 15 saws laying around to cut it out. And now that I think of it, I never had to unbolt a powerhead from a pinched bar anyway.
I like the way that you can mount the chain first, and really dial in the rim to driver lash. It might just be me but I swear it cuts better when that is within spec.
lehman live edge slab
Live Action
9:36 PM
Mn
I didn’t need to unbolt it but was more willing to just loose a bar if something went wrong never know 60-70$ bar or 800-1000$ saw
sawmikaze
10:36 PM
steeltown
You might be the next winner in the cookie club.
Live Action
9:36 PM
Mn
The fact that they came up with the 540 xp mk III indicates that Husqvarna has no intention of abandoning petrol-powered chainsaws anytime soon.
But they are probably fully aware that the demands from big cities are for emission-free technology.
We are already seeing it in Europe, when big cities are issuing contracts requiring battery technology. This applies not only to chainsaws, brushcutters and lawnmowers, but also larger ones.
I am glad that Husqvarna designed the 564 xpg, I see it as the most innovative chainsaw from them in the last 20 years.
I have already contacted my dealer and pre-ordered it. It is a winner in my book.
I’m sure they don’t intend on abandoning them but let’s be honest the 540 mark 3 is out because the first two didn’t work not because they wanted too, same reason to a less extent that the 562 and 550 are on mark 2. Husky has made some great saws but the 5 series overall hasn’t been a shining example of this in the start but they seem to have gotten the new ones better. I’m not claiming Stihl hasn’t had plenty of issues too but I think the 564 may need to be out awhile before I’d try one.
Tor R
Novice, Leg model #2
4:36 AM
Mandal
You're missing the point, Husqvarna hasn't had a pro lightweight since the 339.
And if my memory serves me right, the battery model came out before the mk 3.
Many people thought that was it, when the battery saw came along, we'd never see a Husqvarna gasoline lightweight again, but they surprised us.
EFSM
9:36 PM
Extreme southern IL
I look forward to seeing Echo's version of an electronic carb or EFI. I suspect they are working on it, probably while taking note of the problems that Stihl and Husky have experienced.
Echo told us 5 years ago that they have the tech on the shelf ready when they need it, but they are extremely gunshy at this point. I expect we will see it sometime, but they've made out without it for this long, so maybe they will stick to their share of the market--people who are willing to tote around some extra weight for the trade-off of being able to fix their own stuff.
EFSM
9:36 PM
Extreme southern IL
But is it true that increased stroke means increased torque?
With older tech 2-strokes, this was largely the case, at least in relation to horsepower output. A longer stroke meant you could get larger ports for x# degrees of crank rotation, allowing for better airflow. With strato it seems like we've gone full circle and are heading for the Japanese motorcycle engines of the 50's--20,000 rpm's but a power band so narrow they needed 14 gears.
EFSM
9:36 PM
Extreme southern IL
I wonder if an offset rod like in a diesel would be any benefit to torque on a short stroke saw since all that it does is give it a more efficient angle to transmit force to the crank but maybe with that angle being changed it would increase vibration.
Are you talking about the cylinder not being centered on the crank? I know of only one modern 2-stroke engine like that (Echo/Shindaiwa 30cc SRM-3020/302). It seems like a really smart idea, but apparently there are drawbacks that I'm not thinking of because it's rarely done.
Live Action
9:36 PM
Mn
Supposed to somehow transfer more torque on the crank but I’m not exactly sure how and with the cap the way it is it’s way stronger not that a saw rod would be made like this because they haven’t done a bolt together lower rod in quite awhile.
Ketchup
Epoxy member
8:36 PM
Colorado
Off set bores are more common in 4 stroke, but not common anywhere. In theory they put the piston more over the down stroke and increase duration on the exhaust/transfer side. You have to make that back on the intake side but with reeds or injection that shouldn’t be a big problem.
It’s my understanding that they create a lot of vibration in a single bore engine.
I have wanted to try modifying a case and jug on a long rod saw to be offset towards the exhaust but never actually made a plan.
