husqvarna 562,best ported saw ever?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:57 PM
Provencal, Louisiana
This saw had its squish band cut, pop up turned on the piston, and .070 removed from base. It has a LOT of compression. When the squish isn't to tight, a simple base gasket delete, and strato timing change gives really good results. The compression increase and lower exhaust gave this saw a much wider happy range than those that only have a gasket delete.
Do u change that strato timing on the piston window top edge? I took about 2° off the top edge of my piston window on the 550xp
CapitaineHaddoc
I don't eat frogs
6:57 AM
FRANCE
I can't say it is the most impressive ported saw I own (because my 346's are amazing!), but my WWS 562 is a great runner, great torque, and reliable, but it miss the chain speed of my 346 's.
Randy will build me another 562, I can't wait to try it!
Landmark
Chainsaw Hack
12:57 AM
WNC
The only saw i have sold that i wish i had back is 562. I will have another but prob only with a MM.
11:57 PM
This thread is another example of why I love this place so much. A saw builder starts a thread praising the work of another builder. Names of 5 or 6 builders get mentioned / talked about and no one is arguing, fighting or getting butt hurt.
Thats because we all respect each other. All of these guys build some damn fast saws. I've learned a lot since this site started......I guess you could say I've been schooled. lol
I'd like to thank all the guys that build saws for being a part of this place. Thanks for sharing your ideas and experience with us all.
awol
11:57 PM
Cabool, MO.
Yes, grind the piston at the top of the strato tunnel. I would normally prefer to grind the port, but after dropping the jug, there isn't enough room without causing a freeport. These 562s have between 3 and 7 degree difference in timing.
Hedgerow
11:57 PM
I'd like to see a 'well' ported 357 against a well ported 562.
I ported my 357 so it isn't 'well' ported... lol
357's can really scoot, but I'd probably give the nod to the 562.
Of course I have been wrong before, and will be in the future.
Keith Gandy
11:57 PM
MG2186
11:57 PM
Summer,IA
Compare it in what way ?
In smaller wood the displacement advantage is useless , like any tool its built for a purpose..and it shines in its intended purpose.
That is a very true statement! I was cutting Friday with my Tree Monkey 2152 and the other guy had a stock 372 and I was out cutting him in smaller stuff the whole time. He couldn't believe it was only a 50cc saw! He asked if it had a turbo or something on it.... Lol
jmssaws
Banneded
11:57 PM
Did you tell him that it certainly did have a turbo on it? Small shot of NOS too,just to cool the boosted charge.
MG2186
11:57 PM
Summer,IA
Lol! Yea I told him it didn't have a turbo but wasn't stock either! I was running .325-18" bar on it with 8 tooth sprocket and it is fast in anything under 6-8" wood, not so much buried in anything bigger, the look on his face when I told him it was only 50ccs was hilarious
