I think boss monkey had a wrap made up, but there's no stock options. I've wondered about the smaller Huskies too, but my budget is more 3-series than 5-series. Plus, I think you can bolt a 357 wrap on a 350/346.I want a little husky.
I have zero knowledge about these things was wondering the pros and cons about them. Is there a full wrap available?
Thanks
The 562 3/4 wrap handle can be made to fit - almost. On this video it isn't bolted down on the clutch side. With a bit of bending it might be possible to line it up with the bottom bolt?
I don't know if @Mastermind did get one made.
https://opeforum.com/threads/550xp-3-4-wrap.23164/
Didn’t you do a 2252 for someone, thought I remember a video of you with one?Does the 545 have smaller transfer caps compared to the 550 like the 555 vs 562 does? I’m not certain I have ever ported a 545
Can’t remember. Maybe @Hall84Didn’t you do a 2252 for someone, thought I remember a video of you with one?
Why? What ignition timing, or port timing/area differences are there? Or are the stuffers and transfer caps the only difference? Do you compensate the port work for no stuffers, or use no stuffers to your advantage?But are down on power to begin with.
