Husqvarna 390xp build
srcarr52
4:36 PM
Iowa City
When I bought this tool, it came with a couple of these CCMT inserts. I did purchase a package of the CCGT inserts, but these ones have been laying down a really nice finish, so I have been using them. Perhaps I will switch and save these inserts. You should be charging for all the machining advice ;)
Maybe I shouldn't be giving so much advise, I just realized I do significantly less cylinder machine work for other people than I used to.
farminkarman
I like the red & black ones
3:36 PM
Neenah Wisconsin
The first letter is the shape (C=diamond), second is the relief angle (C=7deg).
Now the fun begins.
The third letter is tolerance, M being generally molded, G being ground (Sharper but more fragile).
Forth is the hole type, T=countersunk.
Learned something new today!
I appreciate you sharing your knowledge. I have very little machining experience, so it has been a lot of learning since I got my lathe.
3:36 PM
It's also a good time to turn your compound and put a new chamfer at the bottom of the bore to help push the rings in during install.
I like turning a bevel on the outside as well, even though not necessary and quite possibly overkill, it makes me feel better having more available interference to the case, which is rounded in that particular area.
srcarr52
4:36 PM
Iowa City
I do as well. That’s often the first spot to contact the case so it’s a bit on insurance to at least remake the original bevel.
farminkarman
3:36 PM
Neenah Wisconsin
Re-installed the cylinder and then pulled the flywheel to remove some of the cast-in key to allow a timing advance. I ended up with about 8 degrees of timing advance. I’m sure some of you will disagree with my method for shaving down the key, but it has worked well for me.165A0556-A787-47B7-96D3-E08F1A01DC8C.jpeg94375FE4-5BB7-4932-B5EC-3DB9A61FB4FA.jpeg38826471-6E5D-45AB-B204-A2B3DEC06AAA.jpeg775634EB-2847-4AB5-AC03-5D1C5CCA1913.jpeg
Stevetheboatguy
3:36 PM
Nw IL
Re-installed the cylinder and then pulled the flywheel to remove some of the cast-in key to allow a timing advance. I ended up with about 8 degrees of timing advance. I’m sure some of you will disagree with my method for shaving down the key, but it has worked well for me.View attachment 351177View attachment 351178View attachment 351179View attachment 351180
I just found a new favorite way to cut those keys. A fine tooth jigsaw blade clamped in a vice grip. Works real slick.
Steven
magicrat
3:36 PM
San Antonio tx
I just bought a brand new 390xp stock off eBay from kwhite1271(member from years back). It’s Awsome and has great speed and torque. I’m going to keep it on 40 to 1 and hopefully avoid any bearing or crank issues. I do love this saw. I imagine ported she will be a monster in the forest !!
Busa2r
4:36 PM
florida
