Husqvarna 350 P/C
Carhartt
9:13 PM
Central Pa
Do the Intake and muffler from the 350 mount in the 346 and 353? I will ask dealer on price for 346, 350 and 353 kits. Any guesses?
JohnnyBlade
JUST GONNA SEND IT
8:13 PM
Momence,IL
I personally like all of them Tim mentioned. Had all but an OE 346, but ive ran one. They all have their perks. I dont think u can pic a bad choice out of the 4. Up to u @Carhartt:D they can all run really well with the trifecta or turn um up a lil more with porting. If this was a poll im guessing the 346 NE would win.
cuinrearview
Handy dood
9:13 PM
Dowling, MI
If I was only cutting 12" and under wood I'd do a 42mm 346. If it was to be my only saw I'd do a 44.3. If I wanted to mess around with porting and wanted to do the uppers too I'd want a 45mm 350. I've still never ran a 44mm but the 42mm open port 345s run very respectably with that port arrangement. I usually try and have a jug in two or three flavors for this chassis on my shelf.
Kiwioilboiler
346 Pic Examiner
1:13 PM
Marsden Pt, NZ
I've a pair of 345's to make into one, and a 353 which i assume is closed port 45mm (the last one was) to resurrect too. I like em, but the OE346XB always out shines em.
cuinrearview
Handy dood
9:13 PM
Dowling, MI
I've got a 45mm on a 2152 I'm playing with now that's pretty sporty. 45 will never hang with a ported 346 but you would have to mod one a little to hang. I got a little crazy opening the lowers so the transfer caps aren't coming off again...
Kiwioilboiler
346 Pic Examiner
1:13 PM
Marsden Pt, NZ
No retainer screw meat left? The one i did i just rounded off the sharp un-finished edge on the bridge that blocks the entry to the lowers and fitted a PopTop HiWay, BGD and Red97 Muff too of course. Mate at work who has it now loves it, but he hasn't run a 346XB.....
cuinrearview
Handy dood
9:13 PM
Dowling, MI
no more gasket flange20190924_103524.jpgAnd that's not even finished...
Turner Saw
9:13 PM
Ohio
I recently ported a 353 cylinder and put it on a 350. The saw runs amazing. Removable transfer covers made it simple to port. I've seen a lot of negative reviews on the 353 cylinder but after doing this build I'm real happy with it. Something to consider for a 350 upgrade
cuinrearview
Handy dood
9:13 PM
Dowling, MI
The 350 and 353 cylinder are the same cylinder. Same PN look it up.
Turner Saw
9:13 PM
Ohio
My 353 cylinder is a closed port cylinder with removable transfer covers. The 350's I have disassembled all had open port cylinders. Did they stop using the open port cylinders at some time?
Kiwioilboiler
346 Pic Examiner
1:13 PM
Marsden Pt, NZ
351's used the 44mm open port cylinder, no doubt the one you've seen on 350s, so must be early editions ay.
