Husqvarna 2100 thread
Jake Dykstra
11:04 AM
NW Washington
Picked this beautiful 2101 up few months back. Pretty sure it doesn't have more than a handful of tanks ran through it.
Sloughfoot
11:04 AM
Norcal
Merican weights and measures, riddles, bent nail puzzles. Not much difference.
Jusgunn3
11:04 AM
California
Welp, got another one delivered today. It has a b stamping on the jug and the rings look pretty thin. Piston and cylinder look great. Cleaned it up a bit fueled it up and it runs good. Needs some new oil lines and the clutch side lower muffler bolt hole is stripped. Over all in good shape!
Jusgunn3
11:04 AM
California
Were you pleasantly surprised it was a thin ring or did you know already?
I had no idea that it was, I didn’t realize it until I popper the muffler off. Then I took off the top cover to check out the cylinder. Why are they more sought after? I do not know much about these bad boys but I love um!
Sloughfoot
11:04 AM
Norcal
Arguably faster. Definitely rare. There's a piston/ cylinder combo that gives more compression. Both are marked A,B or C depending on their metrics. Don't remember which is what.
Squareground3691
2:04 PM
New England
A is the smallest diameter and moves up with with B then C the largest diameter, with a couple thousandths of an inch, The thin ring version I put together not long ago, runs well, but hard to find NOS rings,IMG_0686.jpeg
hacskaroly
2100 Fanclub Member
11:04 AM
Northern Idaho, Ehh
Whatever it is, I don't have it with mine, I have the chubby ring style, but that is ok. I'm not trying to theorycraft mine and squeeze every last bit of power from it, if I did, I would probably break it in the process! :D
