Husqvarna 2100 thread
thedude74
Bonafide & Stuff !!!
8:06 PM
Alaska
Looks like there's quite a bit of ignition timing adjustment due to the slotted screw holes... Where to set it?🤔
Final port timing numbers are 98.5, 120 and 75.
thedude74
8:06 PM
Alaska
Well it runs....like crap😑
Ran good with no issues as 285.....
Acts kinda like an air leak....but it idles fine...has a weird mid range stutter that can't quite be tuned out....will rev out to 12,500 then acts like a limited coil... Saw a backfire on the intake side..
The rattle ball governor has been plugged.
Gaskets look good. Coil is advanced all the way. Maybe too much? Idk. Guess I'll pressure/ vac test the case when I have time.
hacskaroly
2100 Fanclub Member
8:06 PM
Northern Idaho, Ehh
On the 2100 there is a brace that holds up the carb and mounts to the case, I would imagine that this is due to how the carb is mounted and the weight of the air filter that (without the brace) could push down on the intake mount causing air to leak in.
hacskaroly
2100 Fanclub Member
8:06 PM
Northern Idaho, Ehh
Is that a 045 ignition???
It is a 285CD Bosch setup
thedude74
8:06 PM
Alaska
Thanks! I'll have find or make a carb brace. Don't recall ever seeing one on the carb....Though it was likely removed previous to my ownership.
David Young
Safety First !!!!!!
11:06 PM
vt
that should clean up easy enough. I would really scrutinize the edge of the port. I would probably remove that area that was dented and a little above it.
Look how square that intake was. super cool.
Chainmale
3:06 PM
Tasman New Zealand
I think I could slightly shape and re-chamfer the exhaust roof to suit. There's a couple little bits of transfer that can be removed. Don't think I'll get the gouging out completely but can already hardly feel them by finger, and they haven't broken through the plating
Squareground3691
11:06 PM
New England
Easy way to remove a 2100 Flywheel, take pressure off saw and onto Flywheel, these things can be a real problem after a few decades of being on and image.jpg ruined if not done properly to flywheel or crank ,image.jpg
hacskaroly
2100 Fanclub Member
8:06 PM
Northern Idaho, Ehh
My 2100 has worse marks and gouging and runs without issue. I did what I could with some scotchbrite to knock down anything that would be an issue.
Chainmale
3:06 PM
Tasman New Zealand
That's good to hear. In those pictures I had already honed it a bit with sandpaper on a dowel with the drill. There's still a couple of bits of transfer to remove.
