Squareground3691
- 8:13 PM
- May 1, 2021
- New England
6" is Mongo sized? What great news!!!!!!!I have to say that my Uni is mongo sized...at least 6"...
I have this on mine, I didn't want to pay $100 for a crappy used OEM filter off of eBay that looks like it was used for scooping mud for the last 20 years. The unit was super easy to attach with the v-stack adapter.possibly a v-stack/uni setup
What piston do you have? How long of a bar do you want to run?The end goal is to have a fun, fast saw to run a few times a year. Will run 3/8 and 8 or 9 pin.
For port #s I'm thinking 99* ex, 78* intake and maybe 125* on the transfers.
Do those sound decent?
Obviously going to mod the muffler, cut the base and chamber and maybe swap to a 288 intake and possibly a v-stack/uni setup....timing advance???
Suggestions would be appreciated.
Thank you.
It's a pro line window type piston. Thick ring type I believe. Plan on only running the top ring.What piston do you have? How long of a bar do you want to run?
Right on. Yeah, some of that used oem stuff is outrageously priced. Where did you get the v-stack and adapter from?I have this on mine, I didn't want to pay $100 for a crappy used OEM filter off of eBay that looks like it was used for scooping mud for the last 20 years. The unit was super easy to attach with the v-stack adapter.
I wouldn’t count on spanking a good ported 395 with your 2100. If you want it to be fast and don’t need to run a long bar, I would consider a 395 piston. It will allow you to widen the exhaust more. For numbers I would try 96, 116, 76. 98 exhaust is still good for long bar work.It's not going to be a regular use saw....just something to whip out and spank a 395 or 660. Lol....That's the goal anyway![]()
She cuts eh,I wouldn’t count on spanking a good ported 395 with your 2100. If you want it to be fast and don’t need to run a long bar, I would consider a 395 piston. It will allow you to widen the exhaust more. For numbers I would try 96, 116, 76. 98 exhaust is still good for long bar work.
Duke's Saw Shop, it's a Red Beard Saws V-Stack adapterWhere did you get the v-stack and adapter from?
Cool. Didn't know Dukes had V-stacks.Duke's Saw Shop, it's a Red Beard Saws V-Stack adapter
RED BEARD SAWS V-STACK ADAPTER FITS HUSQVARNA 298XP 2100XP 2101XP
I got the Uni filter from HammerHead Performance
Did you also delete the baffle at the exhaust port?
Yea, that was funDid you also delete the baffle at the exhaust port?
Yeah, that part just sucks.Yea, that was fun![]()
