Husqvarna 181/281/288 Repair Thread.
Onan18
OPE Sponsor
9:33 PM
Georgia
Hey Joe -
(..... just because I notice STUFF)
In post #5, the bar mount area on the case is powder-coated. Do you plan to get this down to bare metal?
I had not planned on it, not sure it would make a difference?
Onan18
OPE Sponsor
9:33 PM
Georgia
Spacer washer goes in first.
Then the worm gear, I like to put a little bit of grease in the bore of the gear. Worth noting is on this chassis the worm gear serves double duty as the dust shield, no separate part like on the 272.
Bearing in place...
Drum on, give the bearing a shot of grease.
And spin the clutch on.
Onan18
OPE Sponsor
9:33 PM
Georgia
The operator presence lever can be a little tricky.
New lever and spring.
Spring catches like so.
Slide the lever and spring in from the front.
Use an appropriate size punch or screwdriver to line up the holes, tap the pin back into place.
Done.
rocketnorton
6:33 PM
surrey, bc, can
Hey Joe -
I was curious of same.
Done.
that needs done on another 288 I recently acquired. curious on price on oe topend. runner pic'd earlier got raisman topend kit. blows bout 190.
new project has nice lookin ks top on it. no decomp. is '88 model. has metal cb paddle, too.
Onan18
OPE Sponsor
9:33 PM
Georgia
288 XP 54mm top end Husqvarna P/N: 544 22 31-02
Suggested Retail $202.99 as of 11/17/2017
merc_man
merc_man
9:33 PM
southern ontario
8:33 PM
You're right Joe, the throttle arm is quite unique to this series of saw. One thing I do is check for full throttle operation after assembly. Seen a few that between wear and fatigue only about 3/4 throttle was being achieved. I corrected this by heating up the arm with a heat gun lightly and bending it downwards and let to cool. This seemed to do the trick for me and returned the saw to WOT operational.
XP_Slinger
They’re Just Saws
9:33 PM
Central NY
My 288 had that problem. Fixed as you described, works like a charm.
