- 5:30 PM
- Dec 24, 2015
- Oregon
I had not planned on it, not sure it would make a difference?Hey Joe -
(..... just because I notice STUFF)
In post #5, the bar mount area on the case is powder-coated. Do you plan to get this down to bare metal?
Hey Joe -
The operator presence lever can be a little tricky.
New lever and spring.
Spring catches like so.
Slide the lever and spring in from the front.
Use an appropriate size punch or screwdriver to line up the holes, tap the pin back into place.
Done.
I was curious of same.
that needs done on another 288 I recently acquired. curious on price on oe topend. runner pic'd earlier got raisman topend kit. blows bout 190.
new project has nice lookin ks top on it. no decomp. is '88 model. has metal cb paddle, too.
Thats what the tool looks like for the av mounts. I made needle nose plyers work. Gonna have to invest in them. I got more to do.Let's set the crankcase aside for now and work on the fuel tank.
Needs All new A/V mounts.
No problem.
Having the spanner makes this an easy job.
Done.
You got a part number for that tool? I cant find anything on google for it.
My 288 had that problem. Fixed as you described, works like a charm.You're right Joe, the throttle arm is quite unique to this series of saw. One thing I do is check for full throttle operation after assembly. Seen a few that between wear and fatigue only about 3/4 throttle was being achieved. I corrected this by heating up the arm with a heat gun lightly and bending it downwards and let to cool. This seemed to do the trick for me and returned the saw to WOT operational.
