- 12:35 PM
- Aug 14, 2021
- NorthCountry
I have a few things to fund and my 064 is on the way home so this one is up on the block.
Husky 181se runner with an oem 288 cylinder and AM piston I got off a member here. No other upgrades. Muffler is stock, timing is stock.
New lines, filters, Nachi crank bearings, seals, carb kit. spring av in the back, rubber up front. The front springs and/or rear rubber av can be included. I dont have compression numbers but it feels pretty high. I can just pull it over. Decomp. is currently plugged.
runs and oils as it should. Chain brake works fine.
Older chassis with some blemishes. JB weld repair to the top cover and a couple screws are mismatched, some scratches here and there, etc.
$400 pho +shipping
$400 pho +shipping
