- 11:49 PM
- Jan 8, 2016
- Farmington, CT
pretty sure BPLUST ships to AUS .... would assume NZ also ... so if you need parts, hit him up
There's a vid in the saw video thread
That 394 was a beast
Im pretty sure the high top was an option for those. That's how this one came to me so I'm unsure of any changes made.Very nice Jim.
I take it that saw has the high top on it?
Is there a separate 394 high top cover and filter bits or do you have to use a 395 top?
Did you get the Hyway one?Subbed. I'll be following along with this one. The 394 I just picked up turned out to be a 395! I still can't wait to build it and I have a few parts ordered already. I have one of the Hyway mufflers coming from HLsupply. I'll let you know what the quality is like when it gets here Brewz. Should see it in the next couple days.
Yeah I got the one with the deflector and spark screen. I should see it Tuesday or Wednesday.Did you get the Hyway one?
Thats the one I am looking at.
I tracked down a tall top cover but by the time I get it here I am out $70 plus I need the different neck etc.
Also the filters are harder to get and more expensive.
I would do it for my saw, but this one is a regular work saw so I thing ease of getting filters will be more important.
I will leave it as it is.
I have to remember I am rebuilding a work horse to keep it going, not building a custom hot rod.
That's my plan for the Hyway muffler.Looks like you have plenty of room to add a second port on the clutch side.
Probably get away with opening the whole area under the medium deflector. While opening up the stock outlet a bit too.
This is under the stock deflector.
