How to square file
junkman
Crush it
6:01 AM
pacific northwest
Dang dentist is on strike !
:risas3:
Nails ...........
Friggin nailed a few nails
Was thinking that or by the burnt marks on the one, cutting stumps off again . You will fix it though .I will have to see if can find one of my stump chains ,i bet 1/4 to 1/3 of the tooth has to go they are spooned over so bad .
9:01 AM
Picked up 2 new save edge double bevel files from DDave. I sharpened 36" of full comp, and yesterday sharpened half of a 16" and they won't sharpen left cutters. The top and bottom are fine, but the edges are dull. I'm gonna send them in to get sharpened. Might end up switching brands
Canadian farm boy
“Normal” people scare me.
9:01 AM
Ontario, Canada
What brand of chain?
9:01 AM
36" is old oregon. 16" I'm not sure. They were flawless at first. Huge noticeable difference from my older ones.
It's weird. When I'm filing it'll come up through the top plate, opposite of a beak, and if I push into the side plate it just slides across it without filing. They'll do rh cutters fine. And I can do LH cutters inside out fine.
Canadian farm boy
9:01 AM
Ontario, Canada
Was this chain your filing already square or is it round chain you may of had on your grinder ?
Canadian farm boy
9:01 AM
Ontario, Canada
I had that with a couple pferd files. I came to conclusion it was the stihl chain
Stihl chain is hell on files. It's just so hard. The Oregon chain is much easier to file. Plus the Oregon chain has taller cutters which helps chip flow.
My work chains are round ground Stihl.
My play chains are square filed Oregon
9:01 AM
I've gotten some crappy Save Edge double bevel files, Pferd too
Seems to be hit and miss
What was your solution? I wish several brands were readily available. Must just be us saw nerds are the only ones using them and there's no real market.
Stihlbro
9:01 AM
Virginia
All 4 now do the same thing, but opposite. 2 won't file left cutters. 2 won't file right cutters
Make sure you are not back dragging the file on the return stroke. If you do it will wipe a file out quickly, especially on your non dominant side. It's not uncommon to mark a file to what side of the cutter it does best. I've used colored tape to reference. So, multiple files are needed.
9:01 AM
I hear ya. I'm a knuckle dragger, not a file dragger. I'll keep them for awhile- 1 for left and 1 for right. When that doesn't work I'll send them in to have them sharpened and see how that works
Definitive Dave
Piss Rev Mafia Member
9:01 AM
Central Ohio
save edge sharpens files (any file) cheaper than buying one and if you get one that wont cut right out of the box they replace them free as well
they are good to deal with and quick to respond to any issues
next order I will be getting some goofy files two flat sides and two rounded edges all with cut
John asked me to get theml, no idea how they work yet
Dave
