- 5:42 AM
- Dec 4, 2015
- In a meeting
Dang dentist is on strike !Your tooth's are all crooked and stuff .
Nails ...........
Friggin nailed a few nails
Was thinking that or by the burnt marks on the one, cutting stumps off again . You will fix it though .I will have to see if can find one of my stump chains ,i bet 1/4 to 1/3 of the tooth has to go they are spooned over so bad .Dang dentist is on strike !
Nails ...........
You're supposed to notice the extra beefy chain vice B .............Your tooth's are all crooked and stuff .
What brand of chain?Picked up 2 new save edge double bevel files from DDave. I sharpened 36" of full comp, and yesterday sharpened half of a 16" and they won't sharpen left cutters. The top and bottom are fine, but the edges are dull. I'm gonna send them in to get sharpened. Might end up switching brands
36" is old oregon. 16" I'm not sure. They were flawless at first. Huge noticeable difference from my older ones.What brand of chain?
Was this chain your filing already square or is it round chain you may of had on your grinder ?36" is old oregon. 16" I'm not sure. They were flawless at first. Huge noticeable difference from my older ones.
It's weird. When I'm filing it'll come up through the top plate, opposite of a beak, and if I push into the side plate it just slides across it without filing. They'll do rh cutters fine. And I can do LH cutters inside out fine.
Both already square. Neither have been on my grinderWas this chain your filing already square or is it round chain you may of had on your grinder ?
You said you have 2 files. Do both files do the same thing?Both already square. Neither have been on my grinder
All 4 now do the same thing, but opposite. 2 won't file left cutters. 2 won't file right cuttersYou said you have 2 files. Do both files do the same thing?
Damn. That sucks. I was thinking maybe it was your chain. Apparently not. LolAll 4 now do the same thing, but opposite. 2 won't file left cutters. 2 won't file right cutters
I had that with a couple pferd files. I came to conclusion it was the stihl chainDamn. That sucks. I was thinking maybe it was your chain. Apparently not. Lol
Stihl chain is hell on files. It's just so hard. The Oregon chain is much easier to file. Plus the Oregon chain has taller cutters which helps chip flow.I had that with a couple pferd files. I came to conclusion it was the stihl chain
What was your solution? I wish several brands were readily available. Must just be us saw nerds are the only ones using them and there's no real market.I've gotten some crappy Save Edge double bevel files, Pferd too
Seems to be hit and miss
I hear ya. I'm a knuckle dragger, not a file dragger. I'll keep them for awhile- 1 for left and 1 for right. When that doesn't work I'll send them in to have them sharpened and see how that worksMake sure you are not back dragging the file on the return stroke. If you do it will wipe a file out quickly, especially on your non dominant side. It's not uncommon to mark a file to what side of the cutter it does best. I've used colored tape to reference. So, multiple files are needed.
I was right there next to ya all weekend and you didn't notice?Picture of said knuckles? Both sides ?![]()
