How big of a rim sprocket? Narrow kerf shenanigans
Battle Cross 2
10:05 AM
Southern PA
The 3/8lp/picco rim actually is slightly larger than the standard 3/8". 1.436" vs. 1.381 on the pair I just measured. I remember running across someone saying a worn .404 pitch rim works. I actually turned one down in the lathe and it seems to work. I still would like to find a 3/8lp/picco rim for normal small splines.
I did run 3/8lp on a regular rim with a 525 jonsered. I left the chain slightly loose and it worked. It never seemed "right". No noticeable wear on the rim or drive links after about half life of the chain. I switched it back to .325.
I run a Stihl rim machined by homelite410 on my 490 to run 3/8lp. I've got 5 AM rims I going to try machining for the small spline husky/echo drums. Not many folks interested in 3/8lp so I haven't been in a hurry to get them done.
Pincher
9:05 AM
sw corner of twin cities mn
I attempted to bore one out but found it was too hard for the tooling I was using. Was thinking about annealing one to machine and rehardening. I wonder if my brother could steal some time on his employers wire edm machine. I wouldn't want to know how much that would actually cost.
Duane(Pa)
It's the chain...
10:05 AM
Centre County
I need to try the .325 again. It's been awhile since I played with it.
Stihl 23 RSP is a thing! They obviously decided to re-engineer the shape and steel compound on this stuff. It is hard. I grind, so have no experience filing. It lasted a loooong time before I felt I should sharpen it. Match made in heaven for a 50 cc saw with 8 pin. You cannot duplicate the factory profile without some serious compound filing, but like I said, I eventually squared it on a grinder.
PA Dan
FYD
10:05 AM
White Oak PA
Here are part numbers for 66 and 72 dl chains.
Duane(Pa)
It's the chain...
10:05 AM
Centre County
Like Dan said, I don’t think RSP is a separate entity.
I’m not certain, but I don’t think Stihl made a .325 .050 before this stuff. Could be wrong though...
PA Dan
FYD
10:05 AM
White Oak PA
I never remember seeing any .325 .050 Stihl chain. I don't think they made it since they didn't make any bars in .325 .050. Until now that is.
Duane(Pa)
It's the chain...
10:05 AM
Centre County
Availability is spotty. I’ve seen the Stihl bars in pictures, but haven’t been able to buy one. I am running Sugihara and Tsumura bars without any problems.
Int1968
9:05 AM
Ontario, Canada
Back to regional gauge issues. Stihl .325 has always been .50 in my area. I think the issue you’ll run into when running 23rsp on a normal bar is poor cutting once the teeth are half worn. It’s one of the issues I had when running picco on a 261 with a cannon bar even though it was a narrow kerf bar
PA Dan
FYD
10:05 AM
White Oak PA
Just found out the .325 .050 has been around as the above poster mentioned. It's called the 23RSC and looks like full size .325.
Int1968
9:05 AM
Ontario, Canada
As far as I know all standard stihl chain 325 and 3/8 are built on a standard chassis that’s why the pre-sets are the same regardless of gauge, the driven part of drive links are just ground thinner. The new 23rsp narrow kerf is a different chassis pre-sets are not interchangeable with 23rs chain
