Hinerman
11:30 PM
NE OK
@Hinerman. Isn’t there a WW2 Battleship or sub down there around the Port of Muskogee? I seem to recall seeing one down in that neck of the woods when I used to go thru there with the truck. I thought it was right along the river. Has the river re-floated it? Hopefully it’s far enough away or on high enough ground to be safe from the flooding.
Yes, the USS Batfish; the cables holding it down broke, it floated and stopped in some trees. It did not sink or go down river.
JimBear
11:30 PM
IA
Morning midlanders!
What happened with the dam over by Sabetha? Fail or not?
I haven’t heard anymore on it so I am guessing it hasn’t blown out. The NWS still has a flash flood watch out for that county & after doing some reading I found conflicting reports about whether dam failure was imminent or not & whether water would even effect Hwy 36.
Flash Flood Watch
Flood Watch
National Weather Service Topeka KS
339 AM CDT Sun Jun 2 2019
KSZ011-021700-
/O.CON.KTOP.FF.A.0005.000000T0000Z-190603T1700Z/
/00000.0.DM.000000T0000Z.000000T0000Z.000000T0000Z.OO/
Nemaha-
Including the cities of Sabetha and Seneca
...FLASH FLOOD WATCH REMAINS IN EFFECT THROUGH MONDAY MORNING...
The Flash Flood Watch continues for
* A portion of northeast Kansas, including the following area,
Nemaha.
* Through Monday morning
* Emergency management officials reported the dam located
approximately 2 miles south of downtown Sabetha may fail over
the next few days. A failure of the dam may lead to flash
flooding south of Sabetha down the flood plain of the Delaware
River.
* Roadways that could be impacted by the flash flooding include
168th Road, 250th Street, and 220th Street.
PRECAUTIONARY/PREPAREDNESS ACTIONS...
A Flash Flood Watch means that conditions may develop that lead
to flash flooding. Flash flooding is a very dangerous situation.
You should monitor later forecasts and be prepared to take action
should Flash Flood Warnings be issued.
11:30 PM
Flash Flood Watch
Flood Watch
KSZ011-021700-
Nemaha-
Nemaha.
River.
It hasn't failed yet, still slowly draining. Granted if another good rain comes it might change the outlook of it.
67L36Driver
11:30 PM
MS271 (?) is put together some different.
PTO side is mag, flywheel side is plastic. [emoji848]
And, it could be 44mm, 44.7mm or 46mm. I’m growing skeptical of the starter badge. [emoji57]
11:30 PM
271s top cover is one peice. And yeah its a funky design for sure on the cases. And according to the ipl you have to have a different pto case half if yuy want to get away from the toolless tensioner setup.
67L36Driver
11:30 PM
This is two piece top cover + AF cover.
[emoji90]. Now I have to scrounge a ‘daisy wheel’ adjuster.
Them krauts are so clever.
Plastic clip fastens the AV cable to the cylinder top.
67L36Driver
11:30 PM
Link to a story about an fella driving around barricades & hitting a sinkhole.
https://fxn.ws/2WMABiZ
That dude is an idiot.
I’ve crossed many, many low water crossings in south Missouri. They are designed for water rushing over them. And, every one on a county road had a depth pole marked off in feet & inches. Little Piney River as it snakes around Phelps county is one.
