sawnami
12:17 AM
Springfield
Hey I'm pretty sure we can work something out! How big are you wanting? I had a friend that works at my local dealer made a waste oil stove no wood. Just compressed air and semi filtered waste oil.
I'll have to ponder that. It's uninsulated so it would probably take a lot of BTU to warm it up. Our Infiniti store beside us heats the shop with waste oil and it seems to do pretty good. They have had to have the heater serviced/repaired a few times though.
Sent from my SM-T900 using Tapatalk
moparnut88
12:17 AM
US
The only "service" is the orfice gets clogged. Just clean it. It's made like the forced air kerosene heaters are but it uses compressed air to siphon the oil.
Semotony
11:17 PM
Thanks for the picture in my mind. In return the creek from the kitchen earlier 20181215_092739.jpg
Kinda noisy but it has got 4 feet deeper which is way wider and rough guessing over 10,000 cubic feet in 10 to 12 seconds flow. When I look at that amount of energy rushing thru my place I pray for inspiration on how to convert it to electric. Anything I can afford will break quick.
67L36Driver
11:17 PM
The 445 runs after some priming and pulling. The two SEZ supposedly run.
Hedgerow
11:17 PM
Ain't that the truth! Always thought it would be great to have some of that heat saved for when a guy needs it!
Absolutely..
Sorta like harness the power of a lightning bolt, and run NY City for days..
Harness the heat from a brush pile, heat a house for a couple months..
Hedgerow
11:17 PM
Burning used motor oil can be a pretty dirty business. But it’s a great heat source if you can actually get the burn chamber up to a temp where it’s getting a complete burn...
AKA “no smoke”
Doug could chime in here, as his business is all about burning up the unburnt burnable’s..
