5:27 PM
Sounds like a plan. Muff mod? AM piston? Caber rings. Any simple mods to the jug?
Get a Meteor piston, they come with cabers and it doesn't hurt resale.
When you pop the jug off look at the lower transfers after you pop the jug gasket off. You'll see where you can grind to let it flow better.
countryhog
BTDT
5:27 PM
NW Arkansas
Looks like the 357xp is a 2001 product which is strange since acres says it was introduced in 2003. What gives?
23rd week of 2001. 417th unit made
01 2300417
Semotony
5:27 PM
U betcha. [emoji106]
Looks like a SL-5 starter been put on him.
With any luck it has a Wico magneto.
Found out the sl5 starter is factory. Dang small tab with model: sl5G serial: A2052:eusa_whistle: so much ahead of this one
sunfish
5:27 PM
Success Mo
01 2300417
That's an early one, probably has the funky auto de-comp, that's got to go. Also the very early ones had a different width rod at the top-end, cause issues with replacement pistons. Not sure if yours is that early or not. Damn good saw & well worth fixing. OEM 357 cylinder only, it's a hot rod! The AM junk will not make same power or last near as long. Meteor piston is good though. New oem P&C is around $125 last I checked.
