67L36Driver
- 10:55 PM
- Jan 18, 2016
- Missouri
Morning midlanders!
I'm glad you are getting better SteveMorning everybody.
First morning in a long time I've actually felt this good. Hopefully get to go home today.![]()
Sounds like a plan. Muff mod? AM piston? Caber rings. Any simple mods to the jug?
Found out the sl5 starter is factory. Dang small tab with model: sl5G serial: A2052U betcha. [emoji106]
Looks like a SL-5 starter been put on him.
With any luck it has a Wico magneto.
That's an early one, probably has the funky auto de-comp, that's got to go. Also the very early ones had a different width rod at the top-end, cause issues with replacement pistons. Not sure if yours is that early or not. Damn good saw & well worth fixing. OEM 357 cylinder only, it's a hot rod! The AM junk will not make same power or last near as long. Meteor piston is good though. New oem P&C is around $125 last I checked.Looks like the 357xp is a 2001 product which is strange since acres says it was introduced in 2003. What gives?
23rd week of 2001. 417th unit made
01 2300417
You might get the shock of your life!Out of bed and nosing around my room .
I see this.
View attachment 140079 I'm thinking, "Lets push the blue one, see what happens".
Yeah..You might get the shock of your life!
