Dustin
- 10:38 AM
- Mar 24, 2017
- Rogersville Missouri
Morning all
Sent from my SM-G935T using Tapatalk
Got it now. The lever was hung up on top (covering) the tiny ‘peg’.
Here you go Carl. See if this helps.Nope! Wasn’t it.
I’ll have to hire a consultant.
Ask me if I like a Stihl brake better. [emoji90]
Well I thought he messed with it once then nothing changed so that's when he put it aside.
Echo sell the fuel, return, vent and plug assembly at home depot. I got a Echo string trimmer that wouldn't run worth a crap and replaced that and its still going strong. I didn't even bother with the carb lol.
Here you go Carl. See if this helps.![]()
I will definitely try to do that. Even for a twenty year old unit?
Thanks, Wayne!Echo sell the fuel, return, vent and plug assembly at home depot. I got a Echo string trimmer that wouldn't run worth a crap and replaced that and its still going strong. I didn't even bother with the carb lol.
Ever put the chain brake back together on a brick that somebody popped out thinking they were taking the bar off?Got the 365 chainbrake installed, I think.
Put it together in the ‘set’ condition. Had to chuck the mofo up in the bench vice to crank it to the ‘release’ point.
Will find out if we need a two foot cheater bar to re-set later.
I give Husqvarna a D minus on it.
But Husqvarna didn’t build it...Got the 365 chainbrake installed, I think.
Asianavarna did that one.
Should have put in the plastic ‘shelf’ thingy before dropping the jug onto the crankcase/piston.
‘Do-Over’ next step.
Put the plastic shelf down, impulse line on and the intake on the cylinder before putting the cylinder on.
