lumberjackchef
12:29 PM
Southeast Kansas
OK boys what's the trick? Tensioner is stripped but it won't come out? What am I missing? Should it just pop out ??Don't want to break the case trying to Pry on it... 2159c BTW.
Sent from my MotoE2(4G-LTE) using Tapatalk
Workshop
12:29 PM
Nixa, Mo.
Making progress. Found some fittings at T/S today. Got the valve remounted, son made some brackets to further brace it from movement. That's what caused the crack to begin with. Will make another bracket to mount the filter assembly tomorrow evening then hook up the return hose, fill it with fluid and test everything. Then install trailer lights.
Digger's Dad
Saw-chologist
12:29 PM
Northwest Arkansas
Has it got spark? (I know, stupid question). If it doesn't sit under cover, check the carb float bowl. I bet it has water in it. They won't suck up water.
You missed it but were on the right track with the carburetor. Float hung and dumped half a tank of non-ethanol into the crankcase. Nasty mess. I drained it, flushed with old oil, cleaned the carb and made sure the float was okay. Fresh oil, more fuel and away we go. Starts and runs as it should. I will have to give it a bath before I get to Muskogee. Everything is covered in oily, gassy, greasy grime.
Lights still work! Woo Hoo! Road ready and can't wait to go!
Digger's Dad
Saw-chologist
12:29 PM
Northwest Arkansas
View attachment 13760 View attachment 13760
Looks good, Steve. I see you also opted for the custom fabricated engine cover like I have.
Digger's Dad
Saw-chologist
12:29 PM
Northwest Arkansas
First tree down today had an attitude! Snag a saurus Rex! 24" dbh red oak
finally coaxed her to the ground without major bodily harm or disfigurement!!!! The 046 is a bad arse plunge cutting machine with the 24" hardnose though...love that thing!
Glad everyone is uninjured. I am always worried about snagging something on the way down. I've had a close call once or twice but have always managed to figure a (safe) solution.
Hedgerow
12:29 PM
Pop it straight up and out.
Homelite410
12:29 PM
Belle Plaine
The sweet thing to do chad is pull it out n pitch it and replace with a 2255 clutch cover.
sawnami
1:29 PM
Springfield
There's a guy at work that is wanting to sell a 390 XP parts saw. It looks like the only unblemished parts would be the piston, cylinder, carb, and maybe the crank. I think he said that it lost a battle with a falling tree. Looks like every other part has an "issue" of some sort. I told him I'd see if there was any interest.
lumberjackchef
12:29 PM
Southeast Kansas
That would be nice but I don't have access to any at the moment!! Side tensioner on those I assume.....
I finally pried on it til it started moving. They had tightened it too far and had it all jammed up in the front up against the case. They twisted it so hard it broke one of the teeth clean off of the gears. Chain is obviously stretched and needs a link taken out......
cobey
12:29 PM
Pittsburg, kansas
Hope to have all the parts for Thomas 's
Little xl today. Also supposed to
Get my stihl fuel lines in to fix a couple
Some home owner saws. And maybe fix the goo covered/filled echo
cobey
12:29 PM
Pittsburg, kansas
Did you find a kit?
I need to come get 257 parts from you :)
