hoskvarna
12:52 AM
Iowa
Keaten shot him today
Sent from Hoskvarna Hills
moparnut88
1:52 AM
US
I've been working on an old power products motor. Need to get the flywheel off. It is STUCK. Pb blaster and a puller on it. Smacked the puller with a hammer while under tension no luck. I left it under tension for the last couple days. Only thing I know to do is heat? Anybody got any ideas?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Workshop
12:52 AM
Nixa, Mo.
If its aluminum flywheel I'd be careful with a torch or such. I had a flywheel on my old Briggs that I'd had off 4-5 times when it got stuck. I was able to get it loose with a combination of puller under tension and a prybar behind the flywheel and careful but firm persuasion with a ball peen on the puller.
It was a cast iron flywheel.
plcnut
Jesus is LORD
12:52 AM
Mansfield, Missouri
Maybe you could use something like CRC Freeze-off, and spray it on just the shaft while keeping it tensioned with the puller.
cobey
12:52 AM
Pittsburg, kansas
If you do use heat, plan on new seals :)
cobey
12:52 AM
Pittsburg, kansas
Good Morning everybody.
Preach it Cobey.
my wifey
Took a picture of Daron
Playing in our church band,
He is becoming quite a good woodchuck
And church teacher.
Speaking of Tabby she has lost
Just about 70 pounds since she
Started her diet.
Saw shop staying busy also
moparnut88
1:52 AM
US
Yep its the cast aluminum flywheel. I have let it set under tension. Hoping I come back to it popped off. :)
sawnami
1:52 AM
Springfield
How much is he asking for his surface grinder?
He wants to sell it all together. I'll get his phone number to you. You never know, he might let the surface grinder go by itself since he never set it up in his shop. It's in his basement.
MG2186
12:52 AM
Summer,IA
What about the mill and turning lathe?
sawnami
1:52 AM
Springfield
I learned a valuable lesson using a surface grinder one time. Never, EVER forget to turn the magnetic chuck on. Makes a mess of your precision project.
