countryhog
BTDT
3:37 AM
NW Arkansas
Well, I got it to this point, now planning the next step in the top, drop and roll process.
Be careful using that boat trailer to haul wood. Its designed to carry boats which are significantly lighter than a load of wood. Unless youve reinforced the axle it may fold up on you. Knew a guy that happened to. Driving down the road and before he knew it one if his wheels was at a 45^ angle to the axle. Just sayin
Digger's Dad
Saw-chologist
3:37 AM
Northwest Arkansas
It's quiet in here.
Wood for Good Charity Cut head count:
Marc + 2 (possibly an old, tired splitter)
Workshop & Goldie + Dustin (splitter)
Hinerman + 9 (is that right?) Are you bringing your splitter?
Matt & Levi - Splitter?
Moparnut88 + 1
Nickw + 1
Who'd I miss?
teacherman
3:37 AM
NW Virginia
It's a trailer kit with a 1750 lb payload. It will not haul that big log.
Thanks to Kenneth, it is now on the ground in my driveway.
3:37 AM
If your ever in the market for a new trailer look up Jims Trailer sale in Topeka on South Topeka blvd. They make some to order and are cheaper that TCS or Orschelens. And nice log.
lumberjackchef
3:37 AM
Southeast Kansas
10 degree top plate angle is desirable for chainsaw milling.
Full chisel or semi chisel.
And it will self feed much better if you drop the rakers to .040" after grinding the top plate to 10 degrees....just as in crosscutting full chisel is a bit faster but not as durable of a holding edge.... as semi is not quite as fast bit takes a bit longer to dull in harder density or dirty wood......
Sent from my Moto G Play using Tapatalk
plcnut
Jesus is LORD
3:37 AM
Mansfield, Missouri
If all goes as planned then I should be there. I believe that my helpers are going to be elsewhere though.
Moparnut88 + 1
Nickw + 1
plcnut
WKEND LUMBERJAK
3:37 AM
West of Kansas City
We got to practice leverage and fulcrums and a logs as rollers. The pioneers earned there housing. Oh and cable come a long. Had a good time John. He also to me to a great place to eat called the Mad Hatter. Ate way to much.
Workshop
3:37 AM
Nixa, Mo.
Picked up some overload springs for my truck a couple of days ago. Traded a Lawnboy Duraforce for them. (Those lawnboys are coming in handy) Spent the day installing them and some newish bigger shocks I had laying around. They raised it a couple of inches and now it rides like a serious truck. Reckon this one is a keeper now. :aaaaa:
plcnut
Jesus is LORD
3:37 AM
Mansfield, Missouri
I've always wanted to add air ride to one of my rigs. I just never got around to it though...
cobey
3:37 AM
Pittsburg, kansas
Moparnut88 + 1
Nickw + 1
plcnut
Cobey. .. Probably :)
teacherman
3:37 AM
NW Virginia
So when you say drop the rakers to .040, how is that measured? I'm trying to imagine it. Normally I have a file guide I set on top of the chain and file anything sticking up out of there. Is 040 the thickness the guide should be?
teacherman
3:37 AM
NW Virginia
I went down and visited with them a while back. Great guys. They said if I couldn't find what I was looking for, they'd make it. I ended up going with an aluminum kit from Northern, and my plan is to make the lightest weight covered multi purpose trailer I can. Square aluminum tube ribs and either steel roofing panels or a papier-mâché with waterproof wood glue with a marine coating. It won't be a serious wood hauler, I guarantee it...
teacherman
3:37 AM
NW Virginia
Couldn't have done it without you, Kenneth. The restaurant is called the Mad Greek. Same difference, I suppose. It was a good time for sure!
3:37 AM
Cool they are good people the son lives right across from me and Jims a hoot. What about expanded metal bottom? Or do you need it solid?
