Ethan Hamby
- 3:19 AM
- Nov 25, 2016
- Calico Rock, Arkansas
Looking good. On that mmms head did you measure the ports? Were they wider that stock? Did you grind on the or use the base gasket?With about 5 minutes run time on it lol
I ground a small lip off on the intake but I didn't measure it any. No base gasket put it at .020. when me and Alan look at it I'll see what he saysLooking good. On that mmms head did you measure the ports? Were they wider that stock? Did you grind on the or use the base gasket?
It's supposed to be cast off a cylinder Randy ported but i don't know how far he went on it
Nothing beats sealed beam trailer lights. Run a ground from the truck to every light and you're done!Trailer wiring is always a PITA. It's pretty simple but amazingly frustrating... I will hopefully be acquiring a departed friend's 18' car hauler that I've been using as needed for some time. I will have to redo a bit of wiring but otherwise it's good. Eventually an axle swap might happen for 5k axles just for the better bolt pattern and to have functioning brake on both. I'm a fan of being able to stop in a controlled fashion, when necessary.
What sort of mileage empty and towing do get out of that 5500 Ram and with what gears?Trailer lights can be a pain. Even on OEM factory wiring. New 2015 RAM truck and the right turn signal on trailer would not work. Traced it down to the factory wiring harness had a bent connector pin at a connection under the truck above the spare tire. Grr!
