Workshop
12:35 AM
Nixa, Mo.
Been out in the shop working on the 41 this morning. It might actually make a saw after all. Thankfully I have another little husky to pull miscellaneous bits and parts from. This may be the last of the box saws that I can make a saw from. The rest will be parts and pieces. Except, maybe, a Ryobi. Lots of stuff for them. If anybody needs stuff for a project, let me know what you need and I'll look. It would be best to tell me what model you have and what piece, then I'll have a better idea where to look. It appears everything is 50cc or under. Lots of carburetors.
Different brands I have.
Craftsman, Poulan, Solo, Stihl, Husqvarna, John Deere, Mcculloch and there may be others I'm not aware of too.
Ethan Hamby
12:35 AM
Calico Rock, Arkansas
Just gotta order this at the dealer and I'm home free. Maybe. Lol. Maybe I should get diaphragms to?
67L36Driver
12:35 AM
Found the clutch shoe.
Spring and rim sprocket remain lost.
Note to self: Get out the ladder and check the roof.
67L36Driver
12:35 AM
We are perpetually short on PL/SL type Remington mufflers. [emoji6]
Workshop
12:35 AM
Nixa, Mo.
Did the same a while ago. Thought I had the clutch on tight enough.
Nope! Saw was mounted in the work stand (Thanks Marc) dribbled some mix down the carb to test fire it. It fired all right. Revved up and the clutch hit the wall. Still missing one shoe. It's probably out around Pluto by now.
Put a ceramic type filter in it. Won't pull fuel up the line. Think I'll put a gauze type in, see if that helps.
