67L36Driver
3:55 AM
The Craftsman is a good runner. Hoo Rah!
16" bar until I make spacers later.
67L36Driver
3:55 AM
Good lookin saw there, Carl.
What the secret to your dip?
O'Reilleys foaming engine degreaser. Scrub with mineral spirits and dig out the goo first. Follow up with a jet of warm water from the laundry room hose.
Use the end of the driveway or the chunks will be imbedded in the concrete.
67L36Driver
3:55 AM
All time dirty saw was a Mac 10-10. Filled a '2 lb' coffee can with the goo inside it.[emoji15]
Workshop
3:55 AM
Nixa, Mo.
I cleaned up an old XL12 once. Pulled off the recoil housing couldn't see the engine or cooling fins. Amazingly the piston/cylinder was still good. Turned into a nice runner.
67L36Driver
3:55 AM
Yup. Just like the Mac.
Pulled the recoil and there is the flywheel ............I ..,,...think[emoji33]
Hinerman
3:55 AM
NE OK
Do you worry about getting water in the piston and cylinder or crank case? Or is the saw disassembled when you clean it?
67L36Driver
3:55 AM
Usually sandwich Baggie the carb and plug the muffler outlet. Two with rubber bands.
Run him as soon as possible after or continue disassembly.
Keeps a ton of crap off the workbench.
67L36Driver
3:55 AM
Geez Carl. Thing looks like a new one.
You sure it's not brand new?
My best guess is someone split the fuel tank neck early in its life.
May have throwed a chain once.
Got the replacement tank from Jim.
Air filter on order.
