- 6:32 AM
- Jan 22, 2022
- MO USA
Is your bat needing oiled?.....
From this afternoon in Springfield area.
Sent to me by my brother from TK Elevator
View attachment 488926View attachment 488927View attachment 488928View attachment 488929
Crazy!!! That would kill you if it hit you...From this afternoon in Springfield area.
It would likely work but not well. Some folks use used motor oil for bar/chain oil, I wouldn’t want to see their bars or breathe that crap in.
We had some ulnas rubra in Michigan..View attachment 488940
Got piss elm in the yard between the house and shop. This is nothing like it. Bark is different and red layer under bark were said to be the characteristics of red elm. Not sure what other native elms might be in the area according to conservation website. Either way I might just cut them about 2" thick and throw them in the barn to dry that way.
I was just curious. Somebody sent that ad (from Bomgaars) to me. I am good on bar oil for the time being; usually buy it from Tractor Supply or Bomgaars when it goes on sale. 55 gallons would be way too much.It would likely work but not well. Some folks use used motor oil for bar/chain oil, I wouldn’t want to see their bars or breathe that crap in.
Hydraulic/transmission fluid is what MFA uses for all-season bar oil but they add tackifier to it so it clings to the bar better.
HY-Tran oil is rather thin & runny.
Next time you are up in the SW MO area grab a jug of Buckys Best all season from an MFA to try out. There is a depot on the southwest side of Neosho & one up to Jasper.
They do now have a thicker oil as well.
If you wanting bulk they sell it in 55 gallon drums or will fill you up a 275 gallon tote.
https://www.mfaoil.com/oils-lubricants/other-products/
I have a 55 gallon barrel of Bucky’s I would sell you but delivery may be problematic.
I got a drum..I was just curious. Somebody sent that ad (from Bomgaars) to me. I am good on bar oil for the time being; usually buy it from Tractor Supply or Bomgaars when it goes on sale. 55 gallons would be way too much.
The bark is part of what I was looking at as well. It has a tighter set of ridges than the other stuff around. Don't know if we have much american elm around here.We had some ulnas rubra in Michigan..
I have not found one here in SW Mo..
not sayin they aren’t here, I’ve just never came across one.
The red elms up north had a straighter grain than American elm.
You still using the stuff you got from work?I got a drum..
Just bring jugs..
You need to run your saws more to make a 55 gallon drum more economical.I was just curious. Somebody sent that ad (from Bomgaars) to me. I am good on bar oil for the time being; usually buy it from Tractor Supply or Bomgaars when it goes on sale. 55 gallons would be way too much.
