Workshop
12:13 AM
Nixa, Mo.
I wanted to let you all know my Dad passed away this morning around 11:00. He suffered for a long time and he was a Christian, so I am happy for him.
Sorry for your loss, Thomas. But happy he is with the Lord now. I lost my Dad when I was 25. I still miss talking to him.
EFSM
12:13 AM
Extreme southern IL
Question on moisture meters..
Are they generally accurate?
I took a pecan split and split it again, then tested the raw face.. got 15.5%..
Seems a little soon to be that low.
I bought this a few weeks ago and it has been quite consistent. Make sure you have it set for the right species of wood. What model and brand do you have? It seems like there are only a few trusted brands.
Only the Tony
12:13 AM
Morning all, 43° to lower 70's. Getting some wild temp swings for February. Four more weeks until clock change and lots of evening light for getting some stuff done.
Junk Meister
12:13 AM
Nebraska
Fair
33°F
1°C
82%
SE 6 mph
30.01 in (1016.6 mb)
28°F (-2°C)
10.00 mi
27°F (-3°C)
9 Feb 6:53 am CST
[td]
Humidity
[/td]​
[td]
Wind Speed
[/td]​
[td]
Barometer
[/td]​
[td]
Dewpoint
[/td]​
[td]
Visibility
[/td]​
[td]
Wind Chill
[/td]​
[td]
Last update
[/td]​
Extended Forecast for
Table Rock NE
  • Today
    Today: Mostly sunny, with a high near 72. South southwest wind 7 to 16 mph, with gusts as high as 24 mph.
    High: 72 °F
    Mostly Sunny​
  • Tonight
    Tonight: Mostly clear, with a low around 35. South southwest wind 10 to 15 mph becoming north northwest in the evening. Winds could gust as high as 26 mph.
    Low: 35 °F
    Mostly Clea​
  • Tuesday
    Tuesday: Mostly sunny, with a high near 52. North wind 8 to 14 mph, with gusts as high as 21 mph.
    High: 52 °F
    Mostly Sunny
  • Fairly nice weather for time of year I don't know what i did when I copied this off of my weather page​
  • Just consider the sorce.​
Sawdust Man
Manufacturer of Sawdust
12:13 AM
MO USA
Sawed up the mystery log.
Stinks like....oh my!
Cedar elm seems the most likely ID on it.
Pretty blah looking wood.
Cuts about like red oak I'd say.
I'll make firewood out over the rest of the logs and report back on it's splitting characteristics.....
20260209_083418.jpg20260209_084254.jpg20260209_084306.jpg20260209_091226.jpg20260209_091234.jpg
Junk Meister
12:13 AM
Nebraska
View attachment 482266View attachment 482267View attachment 482268View attachment 482269View attachment 482270
My first thought was The grain has some characteristics to CATALPA How dense is it I seldom see a log that good but the lumber is strong yet light. does have an odor of its own.
Hedgerow
12:13 AM
Not sure..
Just one I bought on Amazon.
Sawdust Man
12:13 AM
MO USA
Way too warm, and a bunch of blood thirsty mosquitoes out there....
The boys and I goofed around with rocks this afternoon.....
Building a retaining wall on the low side of the shed.....well, we're attempting it anyways.
Hedgerow
12:13 AM
This one..
JimBear
12:13 AM
IA
I had one of those & got along fine with it, until my wife touched it & it hasn’t been seen in 2 years.
I had a painless one, it seemed to work best on cut lumber not well for firewood.
I loaned it to a guy & have yet to see it again, that was about 3 years ago.
I bought a pin type from Menards & the tips were so fine that the bent.
I don’t believe I will buy another one.
Only the Tony
12:13 AM
So a pinless meter placed randomly on a board is more accurate than one that goes into the wood is more accurate??
Pardon my annoyance..
I just wanna know what the hell im dealing with.
Questions like this get me sidetracked. Squirrel. Now I had to read up on things I don't plan on using anytime in the future but anywho.
Pinned meters are supposed to be more accurate for wood and substrate like it. Works by checking electrical flow between pins based on water in the test item. You can also drive in small nails and use them to test wood for moisture content at deeper levels.
Pinless use radio frequency or capacitance to measure moisture content when you don't want to leave holes in something or the surface is hard and cannot be probed. These are also relying on the material to be consistent density (which is why you have to chose what material you are testing) in order to provide an accurate reading. These are also affected by anomalies in the material being tested, think metal in the wood, which can throw off the reading.
Best case is use both for a while until you can get similar readings.
