- 10:15 AM
- Jan 20, 2016
- NE OK
TruthSo many saws so little time.
Nobody likes a quitter...Got a nice big pecan tree from a tree service dump. Nice long and straight limbs. I was salivating when I saw it. After hitting metal 4 times I called it quits!!! Damned yard trees!!!
View attachment 338804 View attachment 338805 View attachment 338806
Ooof. So how far into the tree was it? 30 years would've made it several inches into the tree wouldn't it? That maple metal I hit was 8 rings in from the outside.Found a dog chain wrapped around once. Bout 30 years prior to dropping the tree.
Get back after it!
About 6 inches, milling an old tree 4 years ago, pleasant memories hang around, right?Ooof. So how far into the tree was it? 30 years would've made it several inches into the tree wouldn't it? That maple metal I hit was 8 rings in from the outside.
A little grease on the sealing surfaces helps that a lot. Dont think husky put a whole lot of effort into that air filter setup, beyond wedging the big carb in there and workin around thatFor you 3120 guys, what air filter system do you run? This 3120 is a huge disappointment. Still can't get it started and when I pulled the carb, there was sawdust fines on top of the diaphragm. I always read that Husky was far superior in the air filter system department, over Stihl, but that's not what I'm experiencing so far.
Is there an aftermarket filter system, like a K&N set up, or max-flo?A little grease on the sealing surfaces helps that a lot. Dont think husky put a whole lot of effort into that air filter setup, beyond wedging the big carb in there and workin around that
Are you???
Traded my tracks for a new set of tires with some credit
Sent from Hoskey Hills
Not that ive seen, but that doesnt mean much haha.Is there an aftermarket filter system, like a K&N set up, or max-flo?
