67L36Driver
- 1:12 AM
- Jan 18, 2016
- Missouri
We have 6 to 8 inches of the white stuff
You have all the luck.
Only a trace in River City. [emoji3060]
Yep. Seen a lot of flat ones on my travels the last couple of weeks.Skunk’s are out and about en’force...
Love a good pine log..Got a nice jag of Ponderosa this morning & hopefully be able to get a few boards out of the 2 logs, if not then I have more firewood.
View attachment 327871 View attachment 327872 View attachment 327873 View attachment 327874 View attachment 327875
Yes, I am thinking I can work around it. It’s a 26” at the butt & 24” at the other end. 7’ long.Love a good pine log..
That heart got a little shake crack in it??
#windy
When you get it up on the mill, try to line up the plane of your first cut even distance from the center on each end. Once you do that, pick the thickness of the boards you want and mill them full slabs. Once you get all the slabs of the proper thickness, you can then pick and choose the boards you want by getting rid of the heartwood”pith” with a circular saw and a chalk line.Yes, I am thinking I can work around it. It’s a 26” at the butt & 24” at the other end. 7’ long.
So there should be some decent boards even after heartwood cracks out.
A few splits on up the tree had ice around heartwood when I split it.
I should get a few boards out of it. The rest will burn nicely.
