Hedgerow
1:28 PM
Well if it does I have an 88 4x4 with 5speed you can have if you come get it.
Lol..
Seems it’s missing on about 2 cylinders.,
Levi put new plugs and wires in it,,
Same miss.. may have to take it to an expert.
I saw where the distributor and rotor is located.,
And I ain’t goin there...!!!
67L36Driver
1:28 PM
Poor boy transfer cover check:
Leveled up cylinder, poured in mix from the ketchup bottle and watched for moisture at seam. Did both sides. No sign of a leak.
[emoji106]
JimBear
1:28 PM
IA
Lol..
Yes, total PIA. This one has a short in harness bundle somewhere,on the fender well. It shorts out the ignition module. It may go a month or a week just great then it won’t generate spark. It would go anywhere I wanted just couldn’t rely on it to start all the time. Local mechanic thought maybe a bump starter to bypass the switch & some of the wiring would take care of it but I just parked it. It is destined for the salvage yard.
MACHINE
2:28 PM
Broken Bow, Oklahoma
Lol..
Check and make sure valves are not stuck ,
Sent from my SM-G955U using Tapatalk
Hedgerow
1:28 PM
Did the heater work??
If so, Levi May want to buy it off you.
Workshop
1:28 PM
Nixa, Mo.
Right up Steve’s alley...
I've always liked Rangers. Had at least a dozen of them. And yeah, the distributor on the 2.9's was a little problematic. It seems like every engine Ford makes you have to take the upper intake off to do simple stuff. 4.9, 5.0 and 351W you gave to take the upper intake off to change valve cover gaskets. I know on the 4.9, when you take the upper intake off you'd better be ready to drop another $100 just to replace other things while your in there because something else is going to go bad 2 weeks after you were in there.
But I still like Rangers anyway. Even after my headlight switch went south at Matt's.
After dark
An hour from home.
It got bypassed.
1:28 PM
WKEND LUMBERJAK
1:28 PM
West of Kansas City
Have had several trucks that size and sold them for the sardine in a can effect.
Don't see a six and a half footer plus fitting in there comfortably at all.
Levi will have fun in that toy for a while
Yep he is young and limber.
